03 PSD 4x2 coil springs
The springs varied depending on what package the truck was ordered with. When I replaced my front springs, it brought it up some, but not as much as the original ones did.
Your options are to look into a leveling kit if you don't mind raising it up 2" - 2 1/2", go to a spring shop and they can custom make you a set of front coils for $400 -$500, or get a set of airbags that slip inside the front coils to stiffen up the front a bit.
I went the air bag route using airlift. I was able to lift the front up about 1/2" and stiffen up the ride a bit. Too much air and you'll need an alignment due to the lift, but the air pressure is adjustable.
