another spin on painted gauges
Old Jul 27, 2009 | 08:26 PM
first today's Avatar
first today
Alright, The gauges show much better at night than the pictures show. I tried to highlight the important part of the gauges in fluorescent for night time viewing. If you look at the factory black and white I highlighted the points they stressed. I made a mistake and brightened the H on the oil gauge instead of the L. There is no glare during the day. If you look at the overlay panel, the letters actually coincide with the gauges. There are squares on the overlay to make the gauges appear to float.
I have some night pictures coming up.
Old Jul 27, 2009 | 08:57 PM
bill11012's Avatar
bill11012
Modular motor junkie
Very nice!!!
Old Jul 27, 2009 | 09:44 PM
first today
Here are the pictures
Total darkness, but the gauges show really well despite the pictures
Around dusk
Dusk at a red light
Day time dash overview
Were you see the aluminum on the steering wheel, that was originally woodgrain
Old Jul 27, 2009 | 09:47 PM
Jmeyer1990's Avatar
Jmeyer1990
if only the lights were a bit brighter, eh?
Old Jul 27, 2009 | 09:58 PM
first today
They are plenty bright, The pictures do not help the final view. That is the factory lights with the blue filters. They are much easier to read at night than before. The danger areas on the gauges stand out more at night also.
Old Jul 27, 2009 | 10:12 PM
4caster's Avatar
4caster
I like it! I plan to do something along that line down the road, but I may turn the gauges over to my wife because she is the artist in the family.
Old Jul 27, 2009 | 10:57 PM
whatthencuz's Avatar
whatthencuz
what kinda aluminum spray did you use?
Old Jul 27, 2009 | 11:46 PM
first today
Krylon dull aluminum.It does not have to spray heavy. I covered them in 1 wet coat. If you spray to close it comes out heavy and you will lose the details on the gauges. Also change your direction to get even coverage.
Old Jul 28, 2009 | 08:34 AM
LARIAT 85's Avatar
LARIAT 85
What I noticed is that something happened along the way and it looks like you broke the speedometer needle or something. In the "before" picture, the needle correctly rests on "0." The "after" picture shows the needle hanging way down around the trip odometer button. It looks strange that way; you may want to fix that back.
You forgot to paint the "crosshairs" on the tachometer gauge to match the other gauges.
You need to color the red on the "L" on the oil pressure gauge.
Also, what is with your truck's temperature? Looking at the gauges, it looks like your truck is on the verge of running HOT!
I also like the fact that you added red paint on the gauges to show the "danger" areas. I always wondered where the "red line" should be on the tachometer on these trucks. How did you decide on 4,000 RPMs, and what engine are you running?
Old Jul 28, 2009 | 01:22 PM
FordNFishinLover's Avatar
FordNFishinLover
Dang man, seems like some are kinda being alittle hard on you! haha
I think it looks great dude! Good work.
Old Jul 28, 2009 | 02:14 PM
first today
My speedo is not hooked up. I am going to redo the oil gauge, when I was painting it I was thinking it was the temp gauge.
The truck doesn't run hot but the gauge does. I have replaced the gauge, sending unit, and thermostat. I had an aftermarket gauge hooked up for a while to make sure and it was right around 190 degrees.
I saw that the 55mph was bold on the speedo so I just did the 4 on the tach since it fell in the same position as the 55mph. My truck doesn't even run up to 2,000rpm.I have a 4 barrel 302.
Old Jul 28, 2009 | 08:02 PM
ctubutis's Avatar
ctubutis
I was gonna say sumthin' about the speedometer needle, too, but figured you'd figure it out.
Regardless, your scheme looks pretty good! Wish I could rep ya for it. I'm doing something
real similar but, because I'm such an **** perfectionist, it's taking me a while....
Old Jul 28, 2009 | 09:50 PM
  #28
Jmeyer1990's Avatar
Jmeyer1990
hahahaha
it would help if i would read them darn posts all the way before opening my mouth ..er moving my fingers I mean...
glad it all worked out for ya.
knowing my luck I will probably break something in the process of taking the gauges off...
ADOR
139
Jan 17, 2020 11:39 PM
48fordcoe
23
Nov 25, 2014 05:04 PM
dohc_chump
Projects
Jan 22, 2011 09:33 PM
75N
21
Oct 7, 2009 11:07 AM
48fordcoe
Large Truck
79
Aug 5, 2009 07:45 PM
