is there a pic of a s5-42 dust cover anywhere ?
Looks like I'll have to holler at the yards 120 miles away and see what they say. I have spent so much time reading and $1.6K on this conversion that I can't stop now.
Or, cut the E4OD plate to fit around the starter hole and jerry rig the lower cover out of tin to cover the lower half of the integral bellhousing. I HATE to to do it but, if that's what it takes, so be it.
I'd still like a pic though............please!
http://jastrauss.fastmail.fm/auto_to_manual_swap.bmp
Is that a good enough picture for you? :)
It's from the "ZF swap" thread Lazy mentioned.
I looks just like the one I got off my 351w+ZF.
Do you need a better picture because you want to fabricate one from an auto?
I've got one loose and can measure its thickness and take a picture both.
Alvin in AZ
Alvin in AZ
I found one. Called all of the yards I could find in OR, no dice. Searched online and found a co. named QuickTime who manuf's. performance engine plates. Only one distributor had one in stock and it was just returned by another customer yesterday. Maybe my luck has changed now......
I'll do a writeup soon here at FTE concerning the bbf/zf swap so it will help others considering the project and I'll include my costs involved without a donor (-time and fuel).
Still saving around $1k over a sd e4od rebuild.
Thanks again all for your help.
The auto one is flat. The ZF one is bent towards the back at the bottom.
<a href="http://s108.photobucket.com/albums/n29/diesel_brad/?action=view¤t=000_0709.jpg" target="_blank"><img src="http://i108.photobucket.com/albums/n29/diesel_brad/000_0709.jpg" border="0" alt="Photobucket"></a>
Yes , i know, my rear main seal leaks......still
