Another tach question
Old Jul 25, 2009 | 11:21 PM
bigfoot22's Avatar
bigfoot22
I tried the search but could'nt find what i was looking for.
Installed a sun tach on my '74.I start the engine the tach works fine,then after 3 or 4 minutes it reads zero.Do I have a bad tach,bad coil or what? Checked the wiring and everything is hooked right.
Thanks for the help.-Ken
Old Jul 26, 2009 | 12:33 AM
montana_highboy's Avatar
montana_highboy
Is it set on 8 cyl.? most tachs are universal and work for either 4,6,8 cyl. depending on where you set it.
Old Jul 26, 2009 | 05:43 AM
bigfoot22's Avatar
bigfoot22
Yes,I set it on 8 cyl. and even tried it on the 6 cyl. setting to see if it would make a differance but it did'nt.
Old Jul 26, 2009 | 08:50 AM
BigBlue88's Avatar
BigBlue88
Does it suddenly drop to zero, or is it gradual? New tach or used? Sounds like an internal overheating problem on the tach. I'd imagine if you had a bad coil, your truck would start to run poorer about the same time the tach dropped to zero.
Old Jul 26, 2009 | 04:31 PM
bigfoot22's Avatar
bigfoot22
It's a used tach.probably 10-12 years old.And it drops grad. in about 4 min.
Old Jul 26, 2009 | 06:25 PM
BigBlue88's Avatar
BigBlue88
Probably a dried out capacitor, especially if it sat in the sun on a hot dashboard for a few years. Caps should have values printed right on them, if you want to try and replace it. If all you want is a cheap tach without the fuss, Harbor Freight sells a $20 "fast & furious" mini-tach that works well enough in my truck (I even modified the electronics to change to a 4000RPM scale).
Old Jul 26, 2009 | 07:57 PM
bigfoot22's Avatar
bigfoot22
Thanks for the help.I'll look into that new tach.-Ken
brobrad
1997 - 2003 F150
Jan 15, 2013 04:10 PM
MineralStang
Electrical Systems/Wiring
Jul 15, 2005 01:04 PM
ddaa99
27
Sep 2, 2004 07:34 PM
todder53
15
Jan 13, 2004 09:35 PM
