Roadmaster Active Suspension?
Old Jul 25, 2009 | 08:23 PM
mgs's Avatar
mgs
I have the DVD and brochure.....How well does it work on the Excursion (2003-V10 Limited with factory sway bars) and do I need it? Does it improve the normal ride and or help towing 4,000-8,000lbs? All opinions welcome! Thanks, Mike.
Old Jul 25, 2009 | 08:50 PM
RMBC Freeride's Avatar
RMBC Freeride
From what I have read here the answer is... YES...
Do a search for "RAS". Lots of members here use them on their EX's and swear by them.
Old Jul 25, 2009 | 09:07 PM
Cardiac69's Avatar
Cardiac69
MGS, I have it on the X in my sig. I towed for a year without them, then put it on. My trailer is a 30', 8000#, camper. Just got back from a 2600 mile round trip into the Black hills and Badlands of S.D. I wouldn't be without it now. I have a rear Helwig sway bar, too, and this just puts the icing on the cake. The X feels like it is planted on the road. Cornering is much more positive (Even less body roll), it eliminated a small amount of porpoising I had on uneven pavement pulling the trailer, and no sag at all pulling my utility trailer, even with my Ford 9N tractor on it.
Do I sound satisfied with the R.A.S.?
Yep.
Old Jul 25, 2009 | 09:24 PM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Absolutely Yes, it handles and feels like a different vehicle, and I too also have the Hellwig rear sway bar.
Just like RMBC said do a search for "RAS" there is alot of reading on this subject.
Am I satisfied...Yes.
Old Jul 25, 2009 | 09:45 PM
EXv10's Avatar
EXv10
OP; Is that a 4x4? Mine has the 1/2" thick half leaf and it is all I need. I mostly off road and don't tow more than my snowmobile but it doesn't buck on steep rocky backroads in 4wd low due to spring wrap.
Old Jul 25, 2009 | 10:29 PM
gr8scott72's Avatar
gr8scott72
Has anyone with the RAS also done air bags?
Old Jul 26, 2009 | 12:40 AM
Stewart_H's Avatar
Stewart_H
Check out this thread. It has a bunch of links to other threads that have RAS info peppered throughout.
https://www.ford-trucks.com/forums/789595-attn-dup-steering-wander-search-results-for-you.html
Look for posts by Joe "X_Hemi_Guy" as he is our resident RAS expert and has documented his RAS experience extensively, and with exacting detail.
Stewart
Old Jul 26, 2009 | 08:06 AM
Cardiac69's Avatar
Cardiac69
Scott, I couldn't imagine anyone needing the air bags along with the RAS system.If you needed both, you would surely be exceeding the GVWR of the X......
MNBenny
Nov 6, 2014 07:44 AM
50f6
Jul 29, 2014 01:25 PM
delgriffith
Dec 19, 2013 09:26 PM
judithgap
6.2L V8
Aug 25, 2013 08:30 PM
Sask-6.0L
Apr 9, 2004 12:02 PM
