wiring info needed
i have the complete engine harness and front compartment harness with the lights and all that came with the engine out of a 95 bronco it includes the main fuze block and the ECU . but what i dont have is the inside harness i just need know how to mate the two together.
can anyone help?
So, before I try to give a an answer, does the wiring that you have include the large multi-pin set of connectors that pass through the firewall? (The 95 that the engine came from would have this).
The interior side of the harness would include the connector for the ECM and branch circuits from the multi-pin connector to the gauges and "idiot lights". While not necessary, you would do well to track down a copy of the multi-pin connector diagram or "pin out" configuration. The Haynes service manual for these trucks is pretty accurate for wiring information and would probably be a good investment. With the information as to which wires are for which device, you can more accurately determine what goes where. The critical circuits are going to be ALL of those that must run to the ECM. So, you are dealing with a MINIMUM of 60 wires to the ECM. To run the engine, as long as the sensors on the engine and the power feeds and grounds are all connected, you should be good to go. If you don't have the interior side of the harness, I would recommend finding one. Running 60 individual wires is going to be a small nightmare.
So basically what I'm looking for is the wiring to energize the ECU and coils, injectors,and the rest of the engine stuff,thru the multi pin fire wall connection to the existing wiring inside the bronco.
I am not afraid of hacking into the multi pin to make this work i just dont to want completely destroy it for future use,as i will probably be the one adding the headlights and other stuff down the road
I bought the chilton manuals for both the 86 bronco and the 95 broncos they are about useless for what i need. just let me know how to get in touch or where to send my e-mail and i will do it.
thanks.
