No power
Old Jul 24, 2009 | 08:25 AM
dpellicone's Avatar
dpellicone
No power
Ok. I messed up. I replaced the TPS, cleaned out the throttle body and put it all back together. the Truck, 85 150, 5.0Fi, will start but when i accelerate it hestiates and will not accelerate. it does stay running but will creep along with out stepping on the gas. Any thoughts?
Old Jul 24, 2009 | 05:45 PM
gotjeepzj's Avatar
gotjeepzj
don't know if this applies to older fords, but did you set the TPS, or just put in the knew one? On older chevies you had to use an ohm meter and adjust it within certain specs then tighten the screws.
edit: If you removed the TB, it could be leaking at the gasket now.
