If running Stage I injectors and stock turbo with custom tunes... would a stock SD HPOP be enough to supply it well? Or would it be better to buy a Adrenaline pump? Would I really notice a difference?
Also, kinda confused on which part IS the HPOP on my truck... anyone have pictures?
A SD pump would do fine with stage 1's. But if you are gonna have to buy a pump, I would spend the extra money on the adrenaline. However, Joey at Terminator Engineering will modify a SD pump for cheap and it does pretty good with my stage 2's. I've heard mixed reviews on the adrenaline, so your guess is as good as mine. But either would be a good choice.
As far as where the HPOP is, if you look down right in front of the fuel bowl, it's the part that's down low in the valley with the two braided lines coming from it going to each head.
