Please help name this part
Old Jul 22, 2009 | 09:33 PM
bill11012's Avatar
bill11012
Modular motor junkie
My 84 6.9 has a part that i do not know what it is.
it is on the drivers side, by the hood hinge.
It has several vacuum lines, and i do not know what it is for.
if any body has pics of the vacuum system on there truck that would be great.
The PO messed the stuff up that the truck would run without.
Old Jul 22, 2009 | 11:14 PM
hilgerbeast's Avatar
hilgerbeast
Sounds like cruise control components to me. Check out a thread I started called "need help figuring out my cruise control" under the 1980-1986 F-series trucks forum. Its on the second page. Someone posted a pic of the cruise stuff. See if the part he is talking about is the one in question. Sorry if you already know that.
Old Jul 22, 2009 | 11:32 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Does it have a pull ring on top?
Look anything like this?
Pull ring in yellow circle.
If so, the lines are fuel lines and it is a water seperator.
The bracket just below the yellow circle that goes to the black cansiter is a cruise control actuator.
Old Jul 23, 2009 | 07:28 AM
bill11012's Avatar
bill11012
thanks guys, looks like my water strainer is gone and the truck has CC.
what should the CC actuator be hooked up to?
If i can find another water strainer, what does it hook up to besides the fuel lines ?
what does the inside of the CDR look like?
I do not think mine is right. It does not have a screen or anything in it.
Old Jul 23, 2009 | 02:33 PM
Lazy K's Avatar
Lazy K
Forget about the water seperator, just use a short length of hard line and a couple of clamps to join the two fuel lines. Then change the fuel filter a bit more often.
Old Jul 23, 2009 | 02:47 PM
bill11012's Avatar
bill11012
That is what the PO did, i did not know if it should be run like that.
Old Jul 23, 2009 | 03:11 PM
LCAM-01XA's Avatar
LCAM-01XA
Well you really wanna have some water separator somewhere before the IP, what I did to my buddy's '86 is bypass the factory unit and install a complete filter head from a 7.3 engine, it has a water separator at the bottom of the filter housing.
Old Jul 23, 2009 | 09:24 PM
Dave Sponaugle
The stock water seperator on the 83 thru 86 trucks was very bad about letting air in the fuel system.
If you have a stock water seperator still inline, it needs to go away.
Fuel supply line from the tank selector valve in, then a line out to the lift pump plus three wires that go to the water in fuel light in the dash.
If it is gone, either swap to a 7.3 style filter/seperator or add an after market water seperator and leave the stock fuel filter.
Old Jul 23, 2009 | 11:56 PM
bill11012's Avatar
bill11012
What is a good after market water separator?
Old Jul 24, 2009 | 01:13 AM
wreckinball's Avatar
wreckinball
Racor, good ones in my opinion.
Old Jul 24, 2009 | 08:54 PM
speedrdr's Avatar
speedrdr
i've got to say that the water separator on my 91 7.3 has been said to suck like a hoover LOL and i'm in the process of doing something different to get rid of it. hate the hard starts.
speedrdr
Old Jul 24, 2009 | 09:52 PM
Dave Sponaugle
The water seperator on the 87 and later engines (7.3 style) are not usually a problem.
I did not realize how bad my original 86 seperator was until I removed it from the fuel system.
No problem with the 7.3 style so far.
Old Jul 25, 2009 | 01:16 AM
Dodge/Cummins's Avatar
Dodge/Cummins
I eliminated the water seperator from my 7.3L by putting on a NAPA filter that contains it's own seperator because mine was letting air in.
I messed around with it first but never got it to work right.
Old Jul 25, 2009 | 03:11 PM
doube_zero's Avatar
doube_zero
Napa Actually offers four styles for the 7.3 spin on filters. They offer the factory two piece which I personally hate because the bottom cap was prone to leaking no matter how snug you made it, A solid filter with just the drain, a solid filter with the drain and water in fuel sensor, and a solid filter with no drain or sensor. I use the one with just the drain cause my wiring for the sensor is messed up. They are also cheaper than the two piece as well.
Old Jul 25, 2009 | 03:30 PM
bill11012's Avatar
bill11012
I will get one of those filters.
thanks for the help guys!
