Oil & Lubrication
grease or no grease
Old Dec 11, 2002 | 06:52 PM
justdoit's Avatar
justdoit
grease or no grease
I've noticed in the owners manual of my ranger,that the front end
should be greased every 15k or so,but no grease fittings,is this just to get you in?
Old Dec 11, 2002 | 07:28 PM
hitecdan's Avatar
hitecdan
grease or no grease
What year is your Ranger? Some vehicles are "sealed" by the factory. Some have holes drilled and tapped, but then are capped off. And some actually have grease fitting installed. Why? Who knows. No grease fitting, but your manual says lube every 15K miles, sounds about right.
Old Dec 11, 2002 | 07:53 PM
justdoit's Avatar
justdoit
grease or no grease
THANKS FOR THE REPLY,TRUCK IS AN 02 WITH THE MAZDA 2.3.I HAVE A 160
MILE ROUND TRIP TO WORK,BOUGHT IT FOR THE GAS MILEAGE,(30)IF YOU KEEP IT UNDER 70.I USUALLY DO MY OWN SERVICE AND DIDN'T KNOW WHAT TO DO ABOUT THOSE BALL JOINTS
Old Dec 11, 2002 | 10:02 PM
Buckarcher's Avatar
Buckarcher
grease or no grease
Old Dec 12, 2002 | 05:31 PM
hitecdan's Avatar
hitecdan
grease or no grease
If the ball joints aren't drilled and tapped for grease fitting, theirs not much you can do. If you take it to a dealer or shop they will probably just tell you they are sealed units. I has an 69 Mustang with the same deal. The ball joint got replaced after 200,000 miles. I wouldn't worry about it too much.
By the way, you may want to turn your caps off. Using upper case letters in a chat room or text based forum is considered the same as shouting.
Old Dec 13, 2002 | 12:20 AM
BigMattXXL's Avatar
BigMattXXL
grease or no grease
Dan's got the right idea - my 1999 Expy has the same deal - sealed units, but they say get a chassis lube every 3,000 miles. Bah-humbug.
XXL
