Cruise Control...
Old Jul 22, 2009 | 01:31 PM
DieselBeast01's Avatar
DieselBeast01
Cruise Control...
My cruise has been out for quite some time now. I am leaving to go on a 700 round trip on August 1, so I need to resolve this problem. I know that my clock spring is out, so will the cruise not work until I fix this, or is there some way that I can bypass the clock spring and make the cruise control work? Any info on fixing the cruise would be great. Thanks guys.
Old Jul 22, 2009 | 01:54 PM
wla6518's Avatar
wla6518
Im not sure on the clock spring, but I do know that the following will cause your CC to malfunction:
-3rd brake light being burned out
-the sensor on your brake master cylinder has failed
-for standards, the sensor on your clutch pedal pushrod is prone to going out as well
Hope this helps.
Old Jul 22, 2009 | 02:19 PM
12ozd's Avatar
12ozd
Replace the clockspring,not hard to do.
Old Jul 23, 2009 | 01:29 PM
DieselBeast01
Where can I get the clock spring from...
Old Jul 23, 2009 | 02:03 PM
1Aauto's Avatar
1Aauto
Former Vendor
HI, I have one here that will fit your application. Here's a link to it below.
Ford Truck Clockspring
Old Jul 23, 2009 | 11:12 PM
DieselBeast01
Thanks Tony...I will be ordering one from you soon. Does anyone have some instructions on how to take the steering wheel off to replace the spring.
Old Jul 23, 2009 | 11:26 PM
robs01f250's Avatar
robs01f250
i would replace the clock spring first. Tony will take care of you
Old Jul 23, 2009 | 11:37 PM
DieselBeast01
I need to know how to get the steering wheel apart and the airbag out.
Old Jul 23, 2009 | 11:42 PM
bunklash's Avatar
bunklash
I found a link here for removing the steering wheel, I'll try to find it again for you.
Old Jul 24, 2009 | 12:05 AM
bunklash's Avatar
bunklash
Here's the links to good how-tos.
https://www.ford-trucks.com/user_gall...&albumid=37403
https://www.ford-trucks.com/forums/69...l-removal.html
Old Jul 24, 2009 | 08:35 AM
1Aauto's Avatar
1Aauto
Former Vendor
Remember to always undo the battery too when working on electrical parts.
Old Jul 24, 2009 | 12:56 PM
DieselBeast01
thanks so much guys. If I order the clock spring from you on monday, Tony, will you be able to get it here before friday of next week.
