'09 Escape questions
It's probably a trade secret or patented.
Heck, it could be that Ford is only a user of the controls, somebody else designed it in a small electronics firm at their kitchen table. My department buys designs like that for our control systems. Why spend lots of money and time "reinventing the wheel" as it were. Write one check and its yours!
I can't say for sure but have read some PR stuff from JTEKT stating that their 4WD units are used in Ford Escapes and other manufactures too. This page: http://www.jtekt.co.jp/e/products/drive02.html shows the unit(s) and at the bottom, the control box. It does look like the 4WD module that's in my console. The manual says that it requires no programming when replaced but who knows how how the whole system works. The PCM, ABS and 4WD module all converse over the CAN buss.
I can see having rear wheel torque in slippery driving conditions but not on dry pavement driving easily. I've pulled the fuse on the 4WD drive module for a few days and can feel better throttle response. On the downside, this lights the dash "wrench" icon but that goes off when the fuse is replaced.
It does leave a DTC stuck in memory that can't be cleared/read with a consumer grade scanner! It "may" have cleared itself after a drive cycle but I was told how to clear it using a ScanGuage-II by the guy who is responsible for all the Ford SG-II coding that's out there.
If I would have know how this 4WD system "really" works, I might have been driving another Ford Ranger instead!
Not sure if the Ranger uses an old manual transfer case, but vehicles like the Jeep Liberty do. Most Liberties are driven in the city, and spend their life in 2WD unless the road is slippery enough to lock the transfer case. Frankly, I think this setup is stupid for the high school girls and other women driving Liberties on the road.
Seems to me the Escape's system is about as good as it gets for a roadgoing AWD vehicle--and similar to Subaru, Honda CR-V/Element, RAV4, etc. although there may be slight diffs in the exact specs of these other vehicles.
George
George
The reason that it annoys me is that the pre-sales info leads one to believe that your in 2WD till conditions warrant 4WD which isn't the case at all. I'll bet that a majority of 4WD Escape owners don't "really" how the system works.
It doesn't bother me that it's automatic or no user input needed but it's called a Intelligent 4WD System. I don't see the intelligent part because it decides to engage under perfectly dry high traction driving conditions.
If it didn't engage under dry conditions, the V6 version would simply smoke the front tires at WOT. Particularly when on an incline.
For the real world of mostly on-road driving, systems like the Escape's beat the heck out of the Liberty and probably the Ranger as well. If you really drive off road a lot, I agree that the Escape is not optimum. But the Jeep weighs about 600 lbs more as I recall.
Having a bit of torque going to the rear wheels at all time makes sense to me. The car will carve around corners better, and imagine being on a dirt road--turning the rear wheel drive on full starting from zero is more likely to put you out of shape than increasing the rear wheel torque from say, 20% to 50%. Along with traction and stability control, the system is way more intelligent than a manual transfer case like in the Jeep.
George
Anybody out there ever smoke the tires on a V6? Lot of weight in the front end.
The 4WD engages at times and under driving conditions that I wouldn't normally engage 4WD if I had the option to do so.
I have a switch for traction control. I'd love one for 4WD!
You are thinking of this like traditional 4WD trucks, not like AWD performance cars. Audis, BMW's etc, with 4WD always run torque through all 4 wheels. It works better for the road....and that includes dirt roads and rallying applications.
George
George
This system is much closer to "full time 4WD" than its so called "on demand 4WD" Where's the "demand" on dry pavement?
If you're more comfortable thinking of it as full time AWD, then think of it that way. I think we have established that the rear wheels will get varying amounts of power, was it 10 or 20% up to 50%? Audis and other AWD performance cars also send all power, in some percentage, to all four wheels. It provides greater handling potential on all pavement, wet or dry.
It seems as though you're mostly concerned with how the Escape differs from how you originally understood it to be (based on marketing-speak) as opposed to how it works for you. The Escape was designed to be as it is on purpose and I believe Ford gave it a great deal of thought. I hardly ever see complaints at all about the Escape's AWD system. Works great for on-road, soft-road, and bad weather. Need more traction? Get gnarlier tires, or winter tires if you're driving in snow and ice.
Not much more I can say here, and good luck with your Escape,
George
George
The description of operation of the Edge AWD, Fusion AWD and Escape 4WD appears to be all the same. I've looked at a Edge AWD and it has the same rearend as the Escape. On a Fusion AWD, it too hard to get a good look but it "appears" to be just a smaller version.
I tried to post a link to a moving graphic on the Fusion AWD but it didn't work for some reason. It shows AWD under different driving conditions. One shows rear wheel torque on a tight curve. I tried that situation but got no torque. Looking for a friendly Fusion AWD owner so I can plug in my ScanGuage-II in and check it out.
Yes, I've heard about boat ramp problems with FWD.
The Escape 4WD or AWD is one of Ford's marketing ploys. Exact same system on a Ford Edge is tagged as AWD.
I don't think 99.9% of buyers know or care about what Ford calls the system so long as it works for their purposes, and that it does. "Marketing ploy" is a bit of a strong term, implying dishonesty, and I think the sales of the Escape and its success in the real world show that it is not a poorly performing product. Look at sales of the Explorer, which has "real" 4WD by your definition, I think. If you want to go rock crawling, buy a Jeep Liberty or something like that. If you want 4-season traction on the road, the Escape would be my choice.
Take care,
George
