cant remove muffler
Old Jul 21, 2009 | 05:26 PM
cbass139's Avatar
cbass139
cant remove muffler
I have tried heating it and I have tried a BFH, now it has been sprayed with Kroil which almost always works but was wondering what others have done to get stuck exhaust off?
Cbass
Old Jul 21, 2009 | 05:43 PM
flatheadjohn's Avatar
flatheadjohn
Get a bigger hammer or use the hot wrench!
Old Jul 21, 2009 | 05:56 PM
thendrix's Avatar
thendrix
Sawzall, die grinder, or, if it's low enough, a speed bump.
Old Jul 22, 2009 | 09:17 AM
BACAGrizz's Avatar
BACAGrizz
Get what part of the exhaust off where?
Old Jul 22, 2009 | 09:44 AM
raerjim's Avatar
raerjim
did you heat it till it glowed red, or just get it "hot"?
Old Jul 22, 2009 | 09:50 AM
51dueller's Avatar
51dueller
To remove exhaust components its best to have an acetylene torch setup. If you want to save the muffler, just heat the inlet red hot and work the muffler off. Now if you don't want to save it just cut it off. Make sure you have good heat on the torch, then cut the inlet off by cutting two horizontal slices in it. You have to be quick or you will cut through the whole exhaust. I do this every day at work and sounds harder than it is.
Old Jul 22, 2009 | 10:45 AM
WALFORD'S 56's Avatar
WALFORD'S 56
If you have no torches and you want it off....use a grinder and cut it off.....works believe me!!!
Old Jul 23, 2009 | 12:13 PM
cbass139's Avatar
cbass139
Thanks everybody, I got it off today. I used a dremmel with a cut off wheel and just made a slice on the muffler and then peeled it right off. It worked on both sides and was real easy and quick. Thanks for all the help, the new muffler is on and hope I can hear it pretty soon. (read my bad to worse thread for the soon reasoning)
