You would think so.
I've only been into Ford trucks for less than two years, even then it's just a hoby, and I can tell a TTB 44 from a TTB 50 just by looking at them and they can't even tell a TTB from a 60.
It makes you wonder how good your alighnment actually is.
If someone came to me for a trigger job on their Remington 700 and I couldn't tell them which trigger they had I doubt they would be very confident in the resuling work.
Actually once he plugged the right equipment info into the alignment machine, the alignment was perfect.
I always ask for the spec to be set to preffered, not just within spec.
I pay more for it to be set that way, but the money is returned with interest with tire wear savings.
I have a local guy now that does a pretty good job.
When I swapped the TTB 44 into my PowerStroke it steered worse than anything I've ever owned and it had a suspension knock in it I couldn't find.
I took it to him for an alighnment and he asked about all of the things I had already checked. I told him it was a '90 TTB 44 instead of a '97 TTB 50.
He alighned it real well, especially compared to how bad it was before and found the knock was the bushings where the calipers mount.
One of the best $100 bills I ever spent.
Job is done! I got to the yard and they only had one 250 out there that was old enough to work. As I was cutting the shackels loose the cordless Dewalt sawzall I had barrowed from a buddy broke in half! When I get home I find out that the main leaf on one of the springs was cracked. Now I decide to just replace the broken leaf on my truck, that goes easy. Well then I figure I should do the same on the other side of truck and viola my main leaf is cracked as well lol. So a 3 hour job in the drive way turned into almost 5. Oh ya taking that main out I realized my shakle was rusted out, what a day. On the brighter side tho I called the yard about the broken main and they cut me a deal, gave me back $30 gotta love that.
