2005 sunroof help
Old Jul 21, 2009 | 11:36 AM
ford4x4956's Avatar
ford4x4956
2005 sunroof help
i have an 05 f150 and im having sunroof problems....when i open it, it wont close anymore...could this be a switch problem? relay??
Old Jul 21, 2009 | 03:15 PM
Twinsdad98's Avatar
Twinsdad98
Could be. Get a pin out and jumper the swtich. If it closes, then its the switch. I don't know if there is a relay, but I would ASSume that if there was one, there would only be one relay so that wouldn't be it. Sounds like a switch issue since it functions one way, but not the other direction.
Old Jul 21, 2009 | 03:44 PM
ford4x4956's Avatar
ford4x4956
tried that didnt work...and installed a working switch off of my buddies truck and still that same...hopefully not a bad motor
Old Jul 22, 2009 | 02:14 AM
FTE Trigger's Avatar
FTE Trigger
I've got a factory pin point test- in PDF format. Its a bit too big to put here. I can send it your personal e-mail addy if you want to PM it to me.
Old Jul 22, 2009 | 03:43 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
have you pulled the fuse yet?
make sure it isn't blown.
Old Sep 29, 2009 | 05:49 PM
Redfish5's Avatar
Redfish5
Rich - I am having the same problem and would like to test the relay vs. switch before simply replacing the switch. Will you please send that same instruction to me if you still have the link?
huckster
2004 - 2008 F150
Jun 27, 2015 07:56 AM
ArtTruex
Jun 23, 2008 04:48 PM
ExpoBoi99
Mar 13, 2004 04:34 PM
HiRiser
Aug 26, 2003 02:58 AM
Yankee In TX
Aug 20, 2003 08:18 AM
