Since I'm lazy and don't feel like looking through 9 pages of mirrors. Do you have an 08' that is just electric adjustable, like a 99' or 00' would be. No turn signals, heat or power telescoping?
Ditto.. Was hoping to find an 08 that was electric, heated, non-electric telescoping, but had body color on the top of the mirror.
This should be the one you're looking for.Also on the site when you go into the mirror section if you choose the year from the drop down box,it'll truncate the options down for you.
will 05 electric tow mirrors fit on an 02 with electric mirrors?
The mirrors should physically fit and bolt right up. The only issue will be the wiring. I believe the connectors are different sizes, but you can either buy an adapter plug or do some custom wiring...
Yes they will fit. Some of the electrical options may have to be wired in tho.
I now have the power fold/extend 08 mirrors on my 02.
Here is a pic I found on fte for comparison. 08 verses pre 08
The wiring was fairly simple and here is a pic of the wiring into the stock harness. You can see more in my gallery.
