How to fix
Old Jul 20, 2009 | 05:40 PM
Brad_9876's Avatar
Brad_9876
How to fix
Ok, I have a 96 F250 5.8 w/o mass air. I scanned for codes the other day and from the memory I got code 172 and 334. I'm just wondering what all I can do to try and fix this codes. And, like i'v seen alot now, it starts hard when its hot. I never used to have this problem. It cranks forever and then I get a cloud of black smoke when it starts. If I floor it it doesn't crank as long but doesn't start immediately still, just no smoke. Any ideas?
Old Jul 20, 2009 | 08:49 PM
guitarnik's Avatar
guitarnik
go to www.fordfuelinjection.com will tell you the codes. also i would say you have a starting problem. bad cables or wek starter maybe. the extra cranking time may be allowing it to flood itslef and when it finally starts it burns all the raw gas off. or theres a slight chance that your getting oil in a cylinder or two that could be black smoke(unlikely but i suppose it could happen)
Old Jul 21, 2009 | 01:56 AM
rostena's Avatar
rostena
172- HEGO sensor circuit indicates system lean (right side)
334- DPFE or EVP circuit above the closed limit of 0.67 volts.
Source- www.fordfuelinjection.com
Old Jul 21, 2009 | 02:04 AM
DasCheckers's Avatar
DasCheckers
Just a heads up, if you don't have Mass Air, then you have what is known as, "Speed Density."
Code 172 is "HEGO sensor circuit indicates system lean (right side)"
This is most likely your O2 sensor on the right (Passenger) side.
Try replacing it first.
Code 334 is "DPFE or EVP circuit above the closed limit of 0.67 volts."
This means that either your DPFE (Delta Pressure Feedback of EGR) or EVP (EGR Valve Position Sensor) is not functioning correctly.
DPFE's routinely fill with condensation and/or go bad. I would pull off your EGR, clean the entire assembly including the EVP and then clear the codes and see if that helps first!
After that, just replace the EVP and then the DPFE.
Feel free to PM me for my phone number for further help my friend.
Good luck!
Old Jul 21, 2009 | 04:13 AM
TexasGuy001's Avatar
TexasGuy001
I agree with the recommendations stated.
Whats the DPFE, is it the sensor on top of the EGR?
I agree about the EVP (I have replaced mine about 3 times), its not sealed and does go bad from moisture. Sometimes it corrodes inside. You can pop off the cap on top if it and see inside it. Its located next to the coil with an connector and 2 vacuum lines going to it.
Old Jul 22, 2009 | 12:17 AM
Brad_9876's Avatar
Brad_9876
Where are these sensors located? and what all should I know as far as removing and cleaning my EGR?
Old Jul 22, 2009 | 07:16 AM
frankyford's Avatar
frankyford
The EGR sensor is located on top of the EGR valve, the O2 sensor is on your exhaust tubing just underneath the passenger side wheel well. You can't miss them. The EGR sensor if I remember correctly, you'll need a socket size 1/4 to get it off and to 02 sensor is a 23mm wrench. Put some penetrating lube on the big nut for your EGR and the 2 bolts holding the EGR on and try not to twist the pipe with nut on it. What I did is hit it the lube several times before I tried to take it off and it came off without any problems. Hope this helps
Old Jul 22, 2009 | 05:22 PM
Brad_9876's Avatar
Brad_9876
Is there any way to test these things to know which one may be my problem? The EVP isn't too expensive, like 40 bucks from napa, but the DPFE is 100. I don't want to just throw parts at it if I don't have to. Thanks
Old Jul 22, 2009 | 05:28 PM
frankyford's Avatar
frankyford
If you could take to napa or autozone they could read the codes for you. You should have the ODB-2 computer, so they should be able to help. If you have the ODB-1 which I doubt you'd have to take it to ford or try to read them yourself. Good luck
Old Jul 22, 2009 | 05:43 PM
Brad_9876's Avatar
Brad_9876
My truck is still OBD I and I have a scanner for it. I had code 172 and 334 stored, and code 334 in the KOER test.
Old Jul 22, 2009 | 08:17 PM
frankyford's Avatar
frankyford
I thought they quit putting the ODB-1's in them after 95, maybe it was just the F-150's they quit putting them in.
Old Jul 23, 2009 | 02:16 AM
TexasGuy001
What is the DPFE?
Old Jul 23, 2009 | 09:39 AM
Brad_9876's Avatar
Brad_9876
Also, is there any way of checking if I have an injector going bad? From what I'v read it has the symptoms, hard to start after sitting hot, and starts easier when I floor it. Just trying to get her running right again
Old Jul 23, 2009 | 11:25 PM
DasCheckers
Alright man, since 172 is a memory code that means that you need to clear the computer. Your O2 sensor could have acted up one day and be fine now so clear the code either via the scanner or by disconnecting your battery overnight.
As for the EGR, do you even know where it is?
This is your EGR,
And located directly on top of the EGR, is your EVP.
In the first photo your can see the exposed threads on the bottom of the EGR, you will need to disconnect the pipe from there.
Then unbolt it from the manifold, disconnect the vacuum line, and disconnect the sensor wiring.
Pull it off, take a photo of inside it, and the intake port, and post it.
Then you need to go work with some degreaser and brake cleaner.
In the bottom where those exposed threads are, there will be a little pin looking peice. See if you can push it up into the EGR with a screwdriver or something. If it moves freely, good!
If it doesn't move freely, even after cleaning, then consider removing the entire assembly instead of buying a new EGR.
If that's the case, refer to this thread.
https://www.ford-trucks.com/forums/8...egr-valve.html
If that is all moving freely, just replace the EVP and see if that clears your code!
There is no way whatsoever to test your injectors yourself. I HIGHLY suggest pulling them all out and sending them in to WitchHunterPerformance.com
I sent mine to Gordon on a Monday and had them back on the next Monday!
It's $19/injector and $10 shipping.
When I sent mine in they were almost all jammed wide open, which is extremely bad! When he sent them back they were all operating like new!
I am extremely pleased with his service! For the money this is what he does,
Originally Posted by WitchHunter
Our 11 Step process includes the following:
1) Injectors are externally cleaned, visual inspected, and numbered.
2) Test injectors for resistance, shorts, and current draw.
3) Perform leak test, spray pattern, and flow rate testing on our flow bench. Record the results.
4) Remove filter baskets, o-rings, and pintle caps. Bead-blast any loose paint and rust from the metal injector body.
5) The injectors are placed in our first ultrasonic cleaning tank to remove and any particles, dirt, etc that may contaminate the next two cleaning processes.
6) Into a second ultrasonic tank they go, they are now cycled on and off allowing the ultrasonic energy to dislodge any particles and build-up inside the injectors.
7) The injectors are now placed in our third ultrasonic tank for additional cleaning using a different cleaning solution. Once again they are being cycled on and off. Our three tank process insures proper results.
8) A high pressure back-flush is done to remove any particles inside.
9) Back to the flow bench for retesting of spray pattern, flow rate, and leak checking. This test data is also recorded
10) Install new filter baskets, o-rings, and pintle caps. (as required)
11) Prepare a comprehensive test report with before and after test data. The injectors are then packed along with the old parts for return.
Originally Posted by TexasGuy001
What is the DPFE?
Old Jul 24, 2009 | 03:47 AM
TexasGuy001
IS the DPFE the thing over by the coil with the 2 vaccuum lines going to id. I thought it was the EVP.
