Stupid Glow Plugs
Old Jul 20, 2009 | 03:55 PM
Talyn's Avatar
Talyn
Stupid Glow Plugs
I'm getting lots of white smoke on startup.
Looks like I'ma have to do GP's and new O-Rings on my injectors.
I was thinking about doing the GP harness while I was in there just in case as well.
What is this gonna cost?
Old Jul 20, 2009 | 04:06 PM
79f-250custom's Avatar
79f-250custom
ur lookin at 100 buxs for 0-rings. 90 bux for the gps. i would just leave the gp harness alone if you dont see any burn pins. but wouldnt be a bad thing to order the harness's and stuff so when they do go you have them on hand.
Mitch
Old Jul 20, 2009 | 04:34 PM
superduty4x4's Avatar
superduty4x4
Get out the multimeter before you go blowing money.
Old Jul 20, 2009 | 04:48 PM
Cuda_jim's Avatar
Cuda_jim
My truck starts and runs just fine...it blows white smoke on start-up normal IMO. It usually means a couple weak GP's not necessarily injector o rings.
As already stated...test them first.
Old Jul 20, 2009 | 05:43 PM
Action4478's Avatar
Action4478
When mine was smoking like that , the next repair I need was an IPR (stuck open)(no start) . After that ,no smoke ...Just a thought ...
Old Jul 20, 2009 | 06:28 PM
Talyn's Avatar
Talyn
It's just white smoke on cold start up for 30-60 seconds.
It was just a puff at first, but its getting worse.
It didn't when I first bought it, but its getting worse. No idea why.
I'm not going to pull no covers to go to town with a volt meter.
I need to redo o-rings on the injectors I think as well. Figured I mine as just well do it all and get it over with.
260k miles. and I'm sure they have never been touched.
Old Jul 20, 2009 | 06:47 PM
superduty4x4
You don't have to pull the valve covers to ohm the glow plugs... get out your frickin' meter and pop the hood mang.
GICIG
G= glow plug
I= injector
C= injector common
Ohm the GP's between the UVCH plug and a good ground, should be between 0.2 and 2 ohms. If not, you know you need to buy 8 new BERU glow plugs and replace them. Then test the GPR for voltage drop, more than 1v dropped across the relay means time for a new relay.
Old Jul 20, 2009 | 07:10 PM
Brown Falcon's Avatar
Brown Falcon
UVC harness costs about $100 or so per side... just in case. Found mine on Ebay
Old Jul 20, 2009 | 07:41 PM
FARM69's Avatar
FARM69
I wouldn't be too concerned about it. Ever since I replaced my o-rings I always have a little smoke at startup. I like to think that's common on a cold start at any temperature.
When my o-rings did go out you could smoke out yard pretty good...
Old Jul 20, 2009 | 08:02 PM
yoslick's Avatar
yoslick
I'd jump the gp relay with a pliars for 60 seconds or so and hit the key, will answer a lot of questions before I'd do anything else....
Old Jul 21, 2009 | 07:50 AM
Talyn's Avatar
Talyn
I'm not asking for a diagnosis, just was asking for prices. =)
But thanks for the information guys.
Old Jul 21, 2009 | 12:12 PM
Neal 97 250's Avatar
Neal 97 250
Usually the GP's run 8-9 or more a piece. I would just look on ebay if I were you. They have best prices. Be sure to get ZD-11's
Old Jul 22, 2009 | 08:51 AM
Talyn's Avatar
Talyn
holy crap, they are that cheep?
I wouldn't bother to check them with meter, just replace them anyways.
Old Jul 22, 2009 | 10:56 AM
superduty4x4
Its your money, but if it were me I'd ohm them out before replacing them. If they are good, put the $70 or so you'd spend toward something else.
Old Jul 22, 2009 | 11:28 AM
1Aauto's Avatar
1Aauto
Former Vendor
We offer these glow plug harness & gasket repair kits that might help you out.
Here's a link to them on our site.
Ford Truck Glow Plug Harness
