1997 PCM code
Old Jul 20, 2009 | 01:56 PM
Neal 97 250's Avatar
Neal 97 250
1997 PCM code
Just curious if you guys would know. What is my PCM code.
I can get in there and look but was curious if you guys would know right off the top of your head.
Old Jul 20, 2009 | 04:49 PM
Cuda_jim's Avatar
Cuda_jim
Neal, check this out:
http://www.thedieselstop.com/faq/949.../pcmcodes.php3
Old Jul 20, 2009 | 06:25 PM
RubberDuck's Avatar
RubberDuck
Also Neal, you can read it with a mirror and flashlight. It should be printed on a sticker just behind the main connection sticking out of the firewall.
Old Jul 20, 2009 | 06:46 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Maybe this is what are you looking for:
<link rel="File-List" href="file:///C:%5CDOCUME%7E1%5CJAGJ%5CLOCALS%7E1%5CTemp%5Cmsoht ml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:ES-MX;} pre {margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Courier New"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
<o></o><o>PCM CODES 1994-97
</o>
94 manual - BEG6 BEG 8 <o></o>
<o></o>95 manual - SOD4 SOD5
<o></o>95 auto - PRY4 TEE4 TEE5
<o></o>96 manual - ALF4 AUG4 AUG6 AUG7
96 auto - MIF4 MIF6 MIF7 NAW4 NAW6 PRE4
97 manual - ALF6 JKA2 JKA3 MLE0 MLE1
97 auto - MME2 MME3 MME4 MME5 MME6 NAW6 TDE0 TDE1 YBT0
To find the code, you'll need a small mirror.
Look under the hood, on the drivers side.
Up against the firewall closest to the fender is a large wiring connector.
Insert the mirror between it and the fender, and read the code off the connector.
It will be backwards because of the mirror.<o></o>
Old Jul 21, 2009 | 12:17 PM
strokersace's Avatar
strokersace
Are the PCM's interchangable between years? For example putting a 97 auto pcm into a 95 auto? I kinda remember swapping out the TEE5 in the old 95 with a NAW4 for some reason. Are there any PCM codes that are better than others? What would the benifits be?
Old Jul 26, 2009 | 05:54 PM
strokersace
Anybody???
Old Jul 26, 2009 | 06:14 PM
RubberDuck's Avatar
RubberDuck
Yes, they are interchangable.
Old Jul 26, 2009 | 08:28 PM
strokersace
Thanks RD. Is there any one of the codes that's a more desired pcm than the rest?
Old Jul 27, 2009 | 10:58 AM
Neal 97 250
I did this. Thanks to you and Jose for the idea.
MLE1
Colorado350
Jul 2, 2016 06:06 AM
JordoTW
1983 - 2012 Ranger & B-Series
21
Jan 10, 2016 10:06 PM
Joel D
Aug 15, 2015 09:07 PM
JJz400
Modular V10 (6.8l)
Jan 21, 2010 03:12 PM
varmintboy54
May 14, 2009 07:53 PM
