Heads, etc.
Old Jul 20, 2009 | 09:26 AM
PrintNCut's Avatar
PrintNCut
Question Heads, etc.
My truck has a 460 with a massive exhaust least leak. I'd like to replace the heads & exh manifolds. Any help?
Old Jul 20, 2009 | 10:00 AM
Franklin2's Avatar
Franklin2
Most all 460's have the exhaust leak problem. Just replace the gaskets if the manifold is not cracked.
The only problem you will run into replacing this stuff is rusted and broken bolts.
Old Jul 20, 2009 | 10:04 AM
PrintNCut's Avatar
PrintNCut
The problem I think is gonna be doing just that without breaking the studs. I don't really know any history of the truck I just got it about a year and a half ago.
Old Jul 20, 2009 | 11:38 AM
Sycostang67's Avatar
Sycostang67
Start soaking the hardware with lubricant way ahead of time, could make the difference between a lot of squeaking and a broken bolt.
Old Jul 20, 2009 | 11:41 AM
uncle.stosh's Avatar
uncle.stosh
You can soak em' all you want. You are going to break some studs, it's inevitable.
Just man up and git er' done.
Old Jul 20, 2009 | 11:44 AM
Sycostang67
I've never broken a stud(knock on wood)...just had the dam nuts round off.
Old Jul 20, 2009 | 12:05 PM
uncle.stosh
Plan for the worst and be happy when it doesn't happen.
That's my philosophy.
Use 6 point sockets and the fire wrench to loosen stuff up first.
