Transfer case help
Old Jul 19, 2009 | 06:21 PM
CRANEOPCCO's Avatar
CRANEOPCCO
Transfer case help
I am in the process of buying a 1999 f-250 7.3 automatic trans. 94,600 original miles the truck is pristine one owner.it has the switch on the dash for the 4 wd,when switching to low 4 wd there is a long grinding where it will not catch or engage,is this electric - magnetic or is this serious.the truck is owned by a very-senior gentleman, i do not think it has been engaged or exercised very often. Thanks not sure what to do???
Old Jul 19, 2009 | 07:54 PM
12ozd's Avatar
12ozd
Are you using the proper procedure for 4 low engagement ?
Old Jul 20, 2009 | 06:38 PM
PSDLOVER's Avatar
PSDLOVER
check the fluid
You may want to check the condition of the fluid in the transfer case. I change mine out every couple years or so. I would like to change mine out right now but stupid Walmart in Kalispell stripped out my fill plug! Anyway, a senior gentlemen may not have changed that out too often if at all. Its kind of a pain in the ****. I bought my truck with 28K on it and 8 mos old. At 32K I changed out this fluid and it was fairly narly looking at that point.
Old Jul 20, 2009 | 08:21 PM
Kwikkordead's Avatar
Kwikkordead
Hmmmm, it's been a while since I changed out my TC fluid.
Thanks for the reminder.
