1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Does anyone use this oil filter on their gas engines?
Old 07-19-2009, 11:03 AM
jac08f250's Avatar
jac08f250
jac08f250 is offline
http://www.fram.com/oil-filters/xtended-guard.php
I use 5w20 mobil 1 in my 5.4. And I have this filter on it right now. The first time I use it. Does this mean I don't have to change my oil for 10k miles? If so that would be great since I put alot of miles on my truck.
Old 07-19-2009, 12:03 PM
jonrjen's Avatar
jonrjen
jonrjen is offline
Boy Howdy, that sure seems like a lot of miles between oil chances. I know I received a letter from Ford saying the oil change interval on my 6.4 PSD should be at 10,000 miles under normal use....of course they also say the only approved filter is the Motorcraft oil filter....who'd a thought that would have be included...LOL.
But on my V-10 gasser I pretty much limit to 5,000 miles between changes. I figure I can get an oil and filter change at the dealer for $19.95 and that is pretty cheap insurance to keep the engine fresh and clean with the the life blood of a gas motor.
Course, I'm an old guy who was brought up on the 3K oil change theory, and well, I don't adjust to some things too easy.
On the other hand, by running 10K between oil changes would look to be more of a "Think Green" and be kind to the planet idea.
My train of thought is to think green....the green in my wallet. What would it cost to replace or rebuild a motor ahead of it's time due to over extending the life of a few quarts of oil. Plus, I recycle my oil....that is Green Enough for me.
Old 07-19-2009, 12:07 PM
jac08f250's Avatar
jac08f250
Hell I'm 27 and I was brought up to change the oil every 3k miles. But since I got this truck I only have used mobil 1 fully syntheic and changed it every 5k miles. But I was seeing if anyone has use this filter and if they really do go 10k miles between oil changes.
Old 07-19-2009, 12:49 PM
jonrjen's Avatar
jonrjen
jonrjen is offline
I guess the easiest way to determine if the filter is worth how it is marketed and delivers as advertised. Would be to give it a try but when you change it the first time at or near 10K take an oil sample and send it in for an oil analysis. I'm sure there would be many folks here that would like to know the out come.
I guess running full synthetic oil, double filtration and a lot of highway miles it sould be doable.
I am curious, if you don't mind me asking. As I said earlier, the dealership charges $19.95 for an oil and filter change. It cost me more to do it myself...which I do from time to time. I have never priced going to full synthetic oil....what is a quart of full synthetic going for now?
Thanks
Old 07-19-2009, 02:35 PM
jac08f250's Avatar
jac08f250
Thanks
Well your v-10 takes as many quarts as my 5.4 does which is 6. I buy the 5 quarts container of mobile 1 at wal-mart for 22 dollars and then for one quart I believe its 4.50 or so. I hated taking my truck to the dealership cause you have to wait about an hour till they are done with the truck. So spending a little bit more money for better oil and only takes me 10-15 min to do my oil change is worth the difference.
Old 07-19-2009, 03:32 PM
ken kenmnedy's Avatar
ken kenmnedy
ken kenmnedy is offline
thats all for mobil1 it cost me 6.90 a qt for castrol syntac and 13.00 for k/n filter every 5k
Old 07-19-2009, 03:58 PM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
A filter alone is not going to extend drain intervals. A large part of the reasoning behind oil changes are that the anti-wear additives get used up and the parts that absorb contaminates that can't be filtered get used up as well.
I'm sure (based solely on their advertising) you could use that filter if you had a premium oil that had the additive package to enable 10K oil change intervals.
Old 07-19-2009, 04:41 PM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
I grew up on the 3K theory, and stick to it on my '77...Havoline 10w-30 oil and a Delco filter.
On the '02 I went by the light that GM gave me. Sometimes I'd go a few thousand past the light always used Havoline 10w-30 oil and a Delco filter.
On my '08 right now I've been going about 9K between changes using Motorcraft oil and filters. Oil doesn't come out too black, no metal, seems to be doing fine. We'll see over the years.
Old 07-19-2009, 05:23 PM
greenego's Avatar
greenego
greenego is offline
If you use the mobil 1 extended performance synthetic you should be okay for 10000 mile oil and filter changes.
Old 07-19-2009, 08:37 PM
rickf92592's Avatar
rickf92592
rickf92592 is offline
This is a very interesting read on oil filters, I only use Purlator Pure One since reading this.
http://motorcycleinfo.calsci.com/Fil...tml#OilFilters
And this about oil
http://motorcycleinfo.calsci.com/Oils1.html
Old 07-19-2009, 08:45 PM
jac08f250's Avatar
jac08f250
And this about oil
That guy is a tool. I have use fram on every vehicle I have owned and never had a problem with any engines. My dad has use fram on every vehicles he has owned and never had any engine problems. Hell one of his vehicles was a suburban that had 250k miles on it and all he use was fram.
Old 07-19-2009, 10:07 PM
rickf92592's Avatar
rickf92592
OK there Billy Bob, no sense letting science or facts get in the way of mis-placed brand loyalty.............yeeehawww!
Old 07-20-2009, 02:17 AM
78bigbronco's Avatar
78bigbronco
78bigbronco is offline
fram has been proven to be just about the worse filter out there as far as filtration is concerned... if that actually makes a difference to the motor isnt always noticable, I'm sure you could probably bypass the filter al together and still get full life out of some motors, just depends.
Old 07-20-2009, 03:30 AM
shanksyamaha's Avatar
shanksyamaha
shanksyamaha is offline
I always used fram filters, because I got my oil and filter at the same time at walmart. Not anymore.. I have read time and time again that fram are junk filters, they fall apart inside and let dirty oil and clean mix. I just would rather use a purolator since I know they are top of the line and priced about the same.
Old 07-20-2009, 04:20 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
I will chime in and mention that unless the filter has a silicone ADBV that it will lead to dry engine starts and extra wear. Ford is aware of this that is why they make the FL-820s filter.
Quick Reply: Does anyone use this oil filter on their gas engines?
