94 150 performance question
Old Jul 19, 2009 | 10:09 AM
cbailey7a's Avatar
cbailey7a
looking for some info on some performance upgrades on a 94 f150 with a 5.0. im a old school carb. guy with a son getting ready to turn 16 and will get a 94 150 from my dad. he wants to up the horsepower a little, but stay in emmision specs. i can suggest a little to him but im not much on computer controlled vehicles. can you get headders, fuel upgrades and so on, bolt on stuff so to speak and where to get them from.
thanks
Old Jul 19, 2009 | 11:03 AM
JLBKOJACK33's Avatar
JLBKOJACK33
Try jegs performance.com,summit racing.com these both will have what you are looking for.
Old Jul 19, 2009 | 03:06 PM
Conanski's Avatar
Conanski
Yes this motor will take a full exhaust system with headers and 1.7 roller rockers no problem. If it's mass air there it will also take a more agressive cam. In both cases the truck will do better with at least 4.10 gears as well.
Old Jul 29, 2009 | 10:09 AM
psi3000's Avatar
psi3000
How about a fuel injector upgrade along with a fuel pressure regulator upgrade. I have a 94 bronco that I want to put a 35-70 psi adjustable FPR on along with 44 psi injectors. Will this be ok with a otherwise stock motor?
Old Jul 29, 2009 | 10:45 AM
Conanski's Avatar
Conanski
No not at all. EFI is not like a carb you don't force more fuel into the motor to get more power, you increase it's capacity to move air and the computer will automatically add more fuel.
Old Jul 29, 2009 | 10:58 AM
psi3000's Avatar
psi3000
Oh, good to know. What do people use the adjustable FPR and the more psi injectors for?
Old Jul 29, 2009 | 11:36 AM
MCA's Avatar
MCA
The stock fuel delivery system has its limits(hp) when you reach those limits its time to upgrade injectors, pumps or increase the fuel pressure to maintain the A/F ratio where you want it.
Old Jul 29, 2009 | 11:46 AM
Conanski's Avatar
Conanski
That's right, the stock 19lb squirters can support around 300hp naturally aspirated(no forced induction) so they typically don't need to be touched until the whole topend of the motor has been upgraded. Things like an adjustable FPR can be usefull on race car but it really won't buy you anything on a street vehicle. When the EFI system is operating normally any change you make to the fuel pressure is immediately compensated for but the computer and the net result is zero gains.
Old Jul 29, 2009 | 12:19 PM
psi3000's Avatar
psi3000
However, if one were to want to upgrade the top half later and needed a new FPR they might as well spend the extra $60 and get the preformance one right? Or will they have to upgrade the injectors as well because the stock injectors can only handle 19psi?
Old Jul 29, 2009 | 03:59 PM
Conanski's Avatar
Conanski
Sure there's nothing wrong with getting an adjustable regulator now. You don't need one of the expensive and bulky billet aluminum ones though this stock looking Holley will do.. http://www.summitracing.com/parts/HLY-512-500/ and get a fluid filled pressure gauge as well.. http://www.summitracing.com/parts/SUM-800160/
Old Jul 29, 2009 | 05:53 PM
Mustang6147's Avatar
Mustang6147
16 years old... Be carefull, to much HP will get a new driver introuble, or at least get his parking pass taken away.
My opinion is, if it is a good runnin truck,forget the headers for now put on a nice cat back system, give it a nice deep rumble, a little crack when throttleing. A cold air intake, somethin shiney and nice under the hood, maybe a tune up with Ford MotorSPort wires.
Sound good and look good, is the safe bet, it wont be long and he will know more about the truck then you anyways.
Old Jul 31, 2009 | 02:10 PM
doug1222556's Avatar
doug1222556
How much HP is too much for a 16 yr old? Some can get in trouble with a KIA, others are pushing over 500 down the track.
Heck- I'm 52, and it doesn't take much to get ME in trouble... I think my Toyota makes about 125?
It is a point well taken though- and something to consider, but it sounds to me like Jr. is going to up the ante with or without good ol' dads help, and at least dad can keep an eye on things if he's in the loop.
Old Jul 31, 2009 | 02:13 PM
doug1222556
What will the 4.10 gears do to highway travel though? I'm not trying to be a smart aleck... (this time), but trying to figure out a good gear ratio for my truck as well.
Old Jul 31, 2009 | 02:42 PM
Conanski's Avatar
Conanski
HWY milage will still be pretty good since the truck does have an OD tranny.. that's assuming Jr isn't doing 100mph all the time.
RPM increases by just 300 at 70mph for example.
Old Jul 31, 2009 | 03:21 PM
doug1222556
What about one with a C4 and smallish diameter tires... (like my'80)?
