Body Bushing Install
Old Jul 18, 2009 | 06:59 PM
rusty1161's Avatar
rusty1161
My truck has the classic 12 year old sagging OEM bushings. They sag so much, that I believe it is the cause of my downpipe rubbing when I get the EGTs up and it expands. It only happens when pulling a good grade for a decent number of miles, like at least 5 or six miles, it happened the first time pulling up out of Santa Clarita into Palmdale/Lancaster on the 14 Freeway. Anyway, time to replace them so I ordered a set of poly bushings.
I just read in the last Diesel Power Mag about the IDI turbo install and they did bushings in that article. They used a gear puller, a section of 4" exhaust tubing and the OEM bolt. I thought I had a piece of 4" in the garage, but no dice. So off to the hardware store to search for a suitable replacement. I bought an ABS 3" coupling. It worked perfectly. I got the middle bushing apart no problem, without too much cursing on that one. I am leaving in the morning for Mammoth Lakes, so I ran out of time and for the life of me could not get the rear bushing apart, so I just got the front and middle one done on the passenger side of the truck, there is more clearance for the downpipe, so I should be good for this trip. I am soaking the rest of the nuts with PB Blaster so that I can knock out the rest when I get back. I didn't take pics this time, I will when I take care of the rest of the bushings. Looking at the driver's side, it looks like the rear is going to require dropping the tank, any tips here? Thanks.
Old Jul 18, 2009 | 11:34 PM
skaterbro's Avatar
skaterbro
Luckily that side-mount tank is much easier to drop than the rear. You should be able to lower it enough without having to disconnect the fuel lines. Of course, use up as much gas in that tank as possible to make it easier to work with.
Get a milk crate or similar object and position it under the tank. Loosen the rear strap first an inch or two then lower the front down to the crate. That should give you the clearance you need, if not find something a bit lower than the milk crate.
