3m tape removal
Old Jul 18, 2009 | 06:15 PM
jimistephen's Avatar
jimistephen
3m tape removal
Is there a easy and cheap (read free) way to remove 3m double sided decal tape? I had some of those window deflectors that covered the vent windows on the side and were just cracked and broken so I took them off, now I need to get the tape off. Any help would be great appreciated.
Old Jul 18, 2009 | 09:53 PM
ReAX's Avatar
ReAX
I've tried alcohol, WD40 and some other oils/acids. The alcohol loosens it up some, but I still end up with a blister on my thumb when removing the tape. You might try goo gone or goop off, they are supposed to easily release adhesives, but I haven't tried it against 3m tape.
Old Jul 18, 2009 | 09:56 PM
420CREW's Avatar
420CREW
There is a kit that you can get rather cheap from an auto parts/ body store that comes with a disc that goes in a drill and works really well.
Old Jul 19, 2009 | 07:20 AM
thomer's Avatar
thomer
The disc works like an eraser and works really well ! I have used Goo gone works ok but finger nail polish remover worked better for me!!
Old Jul 21, 2009 | 05:11 AM
fl1a's Avatar
fl1a
Lighter Fluid.
Old Jul 21, 2009 | 05:30 PM
Medicmike63's Avatar
Medicmike63
I have had pretty good luck with WD40, definitely need to let it soak for a bit.
Old Jul 22, 2009 | 11:41 AM
WilliesSD250's Avatar
WilliesSD250
Ditto on Med.............WD40 works great! When I switched out my Powerstroke badges for my VT365 badges, I just let the door warm up nicely in the sun then used braided fishing line and pulled it behind the badge, effectively removing the badge and most of all the tape. What little bit of tape residue was left was removed with good ol' WD40 and a little elbow grease, followed by some warm soapy water and a clean rinse!
Old Jul 23, 2009 | 11:56 AM
Prestigejason's Avatar
Prestigejason
Eraser wheel is what i use. I even used it on my black truck made no marks. Its fast and dont hurt your fingers.
Old Aug 5, 2009 | 11:09 PM
EPH1ZZLE's Avatar
EPH1ZZLE
i used fishing line and slide in a saw motion the goo gone for the rest Ive never tried the wheel though ill have to look in to that
Old Aug 5, 2009 | 11:14 PM
hp246's Avatar
hp246
Acetone. Thats what the fingernail remover is.
Old Aug 16, 2009 | 07:24 AM
jaydisto's Avatar
jaydisto
just remember that acetone and fingernail polish remover remove paint and clear coat if your not careful try prepall
Old Aug 16, 2009 | 01:20 PM
johnwill's Avatar
johnwill
x2 lighter fluid
Old Aug 17, 2009 | 03:12 PM
Beechkid's Avatar
Beechkid
DO NOT USE ACETONE OR LIGHTER FLUID!!!! GIVEN ENOUGH QUANTITY IT WILL PERMANENTLY SOFTEN THE PAINT!!!!!
1. Fist take a hair dryer and heat the tape to dry the adhesive. It should flake off slowly. You can use denatured alcohol to remove residue. if that fails....
2. Purchase 3M adhesive remover at any auto boby paint supplier. If will dissolve just about any petro/veg based products without damaging paint in any way.
