'01 F250 Crew Cab
Looking for some help regarding power door locks.
Whether using remote key fob, or inside lock switch, one or two of the doors do not unlock, and after pushing the switch several times it's as if the battery is dead.
"Unlock" switch not working from inside the vehicle.
Same issue. Key will mechanically unlock the doors (Truck has no keyless entry). However from inside the truck, the door rocker switch will only lock the doors, not unlock them. So I disconnected the passenger side switch by unplugging the switch from its harness in the door. Then I noticed that the unlock nor lock part of the switch no longer worked. I am guessing the doors "lock/unlock" switch are only powered when both switches are connected to the wiring harness in the door. I am still not sure what keeps the "unlock" part of the switch from working. I'll check out the actuator next.
