Sponsored by: Kumho
oad sensing proportioning valve
Old Jul 18, 2009 | 08:50 AM
pburchett's Avatar
pburchett
I recently installed a set of add-a-leaf springs (2008, Super Crew, 4x4,5.4L, 6.5 ft bed) and it raised the bed level approximately 2 inches. Surprisingly enough it did not alter the ride comfort at all. Hopefully I can haul more without he rear end sagging so much.
I have noticed that the braking effect is somewhat less than it was before the add-a-leaf install. I wondered if the truck has a load sensing proportioning valve for the brake system which now needs adjusting due to the additional bed to axle height.
<O</O
Does anyone know if the 04-08 trucks were equipped with the load sensing proportioning valve, where it is located or if any adjustments are possible?
Old Jul 18, 2009 | 08:37 PM
pburchett's Avatar
pburchett
Load sensing proportioning valve
I meant to put a L in there so the title should read Load sensing proportioning valve
And I could not find the EDIT button...
