08 mirror install, now no start.....
Old Jul 17, 2009 | 06:32 AM
gofast51004's Avatar
gofast51004
Hey,
Looking for ideas to check. I installed my 08 mirrors last night, and now the truck will not start. It cranks over, but will not fire. My DP tuner switch does not light up. I confirmed the cable is plugged into the rear of the switch, and I think it is plugged in to the PCM.....I need to confirm that after work tonight.....Any other ideas?
Thanks
ben
Old Jul 17, 2009 | 06:48 AM
megawatt00's Avatar
megawatt00
Check the fuse that feeds the PCM (the same on feeds the fuel bowl heater) The symptoms that you are having points in that direction.
Old Jul 17, 2009 | 07:00 AM
gofast51004
Good idea....thanks, I'll check that this afternoon....I hope it's that easy.
Old Jul 17, 2009 | 07:03 AM
F350-6's Avatar
F350-6
Since you were playing with electrical stuff, I'd check all the fuses.
Old Jul 17, 2009 | 09:14 AM
jeff7825's Avatar
jeff7825
Did you unplug the cable from your DP switch at all? I know when I first put mine in I had the cable plugged in the wrong way and the switch wouldn't light up and the truck wouldn't start. I turned the plug around and the switch lit up and then the truck fired. Might be something else to check.
Old Jul 17, 2009 | 09:38 AM
gofast51004
I did pull and reseat the cable in the switch, I made special attention to reseat it the same as before. There is a notch on my cable to assure it is inserted correctly. Thanks for the info.
I hope it's as simple as the fuse.....The good news is the mirrors look great, and they work....I guess I should have seen if the truck started last night, and not just the mirror functions....hehehe
Old Jul 17, 2009 | 09:56 AM
BillyBob69's Avatar
BillyBob69
Maybe you can flap the mirrors to make it go?
If you unplugged the main harness to the trucks puter, make usre it is seated COMPLETELY. It can seem to be there but it just isn't all the way in.
Old Jul 17, 2009 | 10:01 AM
dpwilson's Avatar
dpwilson
DOH, beat me to it. More than likely blown fuse. If that isn't the case (sure it is though) my next step would be checking the pcm itself.
Old Jul 17, 2009 | 10:07 AM
just another truck's Avatar
just another truck
Any chance you have "no start"
Old Jul 17, 2009 | 10:36 AM
gofast51004
Yeah, she is a nice looking ride, just sitting there......
-I'll try the mirror flapping idea.
-I do have "no start" on my DP, I thought about that also. I have no idea how it would have fallen into position 0 on its own, because I didn't put it in to "no start". I forgot how to get it out of position 0 this morning, so I printed off the directions and will try it tonight. (not sure if I would see a "0" on my switch when it is in "no start", but I have no lights on my switch right now)
Old Jul 17, 2009 | 11:26 AM
cgl's Avatar
cgl
My "No Start" will let my truck start. It just dies after a few seconds.
Old Jul 17, 2009 | 12:21 PM
just another truck
Mine will not start, and I dont I see anything on the display..( maybe I set the dimmer to though, who knows) Just a thought..
Old Jul 17, 2009 | 12:26 PM
dpwilson's Avatar
dpwilson
I'm pretty sure right when I key on the igntion it illuminates for several seconds and then the screen goes blank. Good possibility your chip is not seeing the remote defaulting to no start.
Old Jul 17, 2009 | 12:27 PM
DieselBeast01's Avatar
DieselBeast01
When I use no start, the truck just turns over, but will not fire. You probably have blown a fuse. there is not much else that can go wrong during a mirror install lol.
Old Jul 17, 2009 | 12:38 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Try pulling them all the way out, then adjust them all the way down, and out to the sides, and try again.
