Need headlight bulb replacement
Old Jul 16, 2009 | 08:50 PM
chazman's Avatar
chazman
whats everybody using these days. I had some aftermarket in thereand one burned out.
Old Jul 16, 2009 | 09:01 PM
TexasGuy001's Avatar
TexasGuy001
If you need a replacement headlight bulb and want better than stock then get a +20 or +30 percent bulb like GE NightHawk (not sport) or Sylvania Xtravision. You can get Nighthawks from Amazon. The Xtravision is available at most parts stores and even walmart. There are some others like Phillips vision plus. These bulbs slightly brighter than stock with no increased wattage. Don't go for the blue tinted bulbs. They actually reduce the amount of usable light. They also tend to run hotter because the coating absorbs heat. Make sure that the bulb is clear. Keep in mind though that any of the brighter lights will most likely not last as long as the long life stock replacement will.
