Update on data plate cleaning
Old Jul 16, 2009 | 05:25 PM
Oakroadjoe's Avatar
Oakroadjoe
Tried the 50/50 vinager water this am and it worked well.Let it sit about 30 minutes,took a SOFT tooth brush and now i can read everything.It is not show quality but for daily drivers it looks good. Thanks Julie
Old Jul 16, 2009 | 09:44 PM
BlueOvalRage's Avatar
BlueOvalRage
Good to hear that you got it cleaned up. I wish mine would be that easy. The PO painted it black along with the rest of the firewall. Getting the paint off without damaging the original paint is going to be interesting.
Old Jul 16, 2009 | 11:21 PM
Julies Cool F1's Avatar
Julies Cool F1
White vinegar is VERY acid. It tends to clean most oxydation - especially aluminum and Copper based metals (brass and bronze). It works well on aluminum wheels and step plates as well. Another household tip from Julieuiese!
Old Jul 19, 2009 | 04:26 PM
Oakroadjoe's Avatar
Oakroadjoe
Vinegar also cleans!!!
Vinegar will also clean light/medium rust off of steel (nuts,bolts etc.)It is cheap.It does smell strong once used so cover it.Sorry for the delay in replying,did a bbq fundraiser for our local VFD last two days
Old Jul 19, 2009 | 07:41 PM
raerjim's Avatar
raerjim
http://www.vinegartips.com/Scripts/p...wSec.asp?id=10
Old Jul 19, 2009 | 09:52 PM
safetymike77's Avatar
safetymike77
Is that with straight vinegar? or a percent solution? most you buy at the store are usually some dilute solution already, iirc.
Old Jul 20, 2009 | 04:48 PM
Oakroadjoe's Avatar
Oakroadjoe
From the bottle,50% water,50% vinegar
