Engine ??
Old Jul 16, 2009 | 01:14 PM
countrykid_86's Avatar
countrykid_86
Engine ??
I am going to pull the valve covers and re-torque the hold downs and pedastal bolts/ inspect harnesses and such. I have had a noise in one cylinder on my engine for about 9 months now. I have had the codes checked several times with CC test and tick test, nothing pops up, but there is definitely a tick/clatter noise especially at colder temperatures. The noise is not always there, only 80% of the time. I am wondering if I have a bent rod. Does anyone have pics, description of removeing the rods, I am guessing it is pretty straight forward.
My gut tells me that its an injector giving me problems, is there a way to figure out which one it is even, since they pass all the tests?
I run Valvoline 15-40 HD Deisel oil during the summer and Valvoline 10-30 during the winter.
Old Jul 16, 2009 | 01:22 PM
Nick 99's Avatar
Nick 99
Do a search on HPX mod, you might fine your answer.
Old Jul 16, 2009 | 01:27 PM
countrykid_86
Thanks, I actually just ordered one from clay, hopefully that will quiet her down a down a little. Does anyone know what the cost is on a HPOP mod, say to a double pump? I suppose if I do that, I should do different injectors also, damn $$$$
Old Jul 16, 2009 | 01:33 PM
03_PSD's Avatar
03_PSD
Probly just hearing the #8 injector firing. I installed the CCK (Cross Connect Kit) and it quieted it some, and I'm about to get the intank mods. I've heard the intank mods really help with the noise.
Old Jul 16, 2009 | 01:37 PM
87 F-150 I6's Avatar
87 F-150 I6
The crackle you hear is the dead head design of the drivers side fuel rail. #8 injector doesn't get enough fuel and it has a knock to it. Duel HPOP will not fix the issue, a regulated return or Crackle cure kit will. Having Duel HPOP may help insure that the injectors get enough oil and a HPX will help with some engine noise, but not completely.
Old Jul 16, 2009 | 06:22 PM
F350-6's Avatar
F350-6
I just heard about a slightly used one here locally for $1000 plus shipping.
