Intermittent Power Loss
Old Jul 15, 2009 | 10:44 PM
praskyd's Avatar
praskyd
Hello all,
I have had an intermittent fuel issue and do not want to spend anymore money for not. The truck runs fine and then usually going up a hill the power will drop off and the SES light comes on. If I pull off and shut the truck off it will disappear for an hour or maybe 2 weeks. The code that comes up is injector pressure above or below desired level. I have changed the pressure regulator, sensor, filter, fuel pump, checked the tank screen with little or no improvement. As of late when I start it in the morning it will start and idle fine, but when I hit the road with my foot in it, it will smoke white for the first 1/8 mile and then all is well. 160000 miles. The wire harness under the valve covers has been replaced too. Any info would be a great asset. Thank you in advance
Old Jul 15, 2009 | 11:29 PM
Kwikkordead's Avatar
Kwikkordead
Welcome to FTE.
What you are describing sounds very much like failed injector o-rings, or a bad IPR (injection pressure regulator), or a failed injection pressure sensor.
I'm leaning toward a blown injector o-ring myself.
EDIT: I should have read more carefully!
You've done everything but the injector o-rings.
Old Jul 16, 2009 | 06:27 AM
F350-6's Avatar
F350-6
Engine oil full and not past due for a change? Are you running a chip or is the truck stock? What are you using to pull the codes? No overboost code?
Old Jul 16, 2009 | 08:12 AM
fifthwheel01's Avatar
fifthwheel01
Welcome to FTE
subscribing
Old Jul 21, 2009 | 10:36 PM
praskyd's Avatar
praskyd
Thanx for the input, I talked to a local Diesel shop and they think that the unit should have the updated o-rings being a 2001. The problem has got allot worse. The smoke is mostly white, with occasional blasts of black. off the get go now. It is going to the shop next week. I will keep you posted on the outcome.
