General Automotive Discussion
Help needed...
Old Jul 15, 2009 | 09:34 PM
FordNFishinLover's Avatar
FordNFishinLover
Help needed...
Okay well my father really needs his car running but we just cant figure out whats the problem.
He drives 1987 302 efi 5.0 lincoln town car
It all started after he washed the engine one day and since then it wouldnt start.
The car "WILL" start if you spray starting fluid straight into it.
It gets spark to the plugs and coil.
We replaced the Fuel pump, screen, and filter
The fuel pump fusable link is good.
We are kinda lost right now. This is his only car and has no money for anything eles at the moment so ANY help is thanked!!!!
Old Jul 17, 2009 | 01:20 AM
ford2go's Avatar
ford2go
Do you have 2 fuel pumps? Ford trucks from that era have an in tank and an in line pump. The tank one just supplies fuel, the inline one boosts the pressure.
Since it's after a wash job, it would seem to be electrical. Can you hear the pump(s) run when you turn on the key? They should run for 2 seconds, and then they shut off until the engine starts. I think that there are relays and an inertial switch in the power wiring the pump(s).
One off the wall thought. If you pull the vacuum line from the fuel pressure regulator, is there gas present? Something could have damaged the diaphragm
