No more rattles!
Old Jul 14, 2009 | 06:16 PM
CanadianSmokie's Avatar
CanadianSmokie
No more rattles!
Finally got around to doing the door rubber mod.
I used the 3/8" foam backer rod and completed all four doors in about an hour. Reduced road noise some (still a little noisy from the MT's) but what I noticed the most was... no more rattles when going over bumps, cracks and potholes... ... feels and sounds like a new truck.
Definitely worth the time and cost (about $10 for 60' of foam)
Old Jul 14, 2009 | 07:02 PM
YellowSled's Avatar
YellowSled
pic pic pic pic!!
Old Jul 15, 2009 | 12:32 AM
BAJI26's Avatar
BAJI26
Where did u get the 3/8" foam backer rod from?
Old Jul 15, 2009 | 11:39 AM
CanadianSmokie
Sorry Yellowsled but I am not good at documenting the things I do with pics and now that it's all buttoned up you can't see anything.
Simple procedure though... unsnap sill plate and pull rubber door seal off. Squirt some soapy water through the door seal opening from both ends (you'll see some leaking out from the small holes along its length). Run a small steel fish tape through and attach the foam with electrical tape to the it. Pull foam into the rubber cavity and leave approx. 2-3" at each end. Re-install rubber on truck and trim excess foam where the two ends meet. Snap the sill trim plate back on and your done... move on to the next door.
Baji, I bought the foam backer rod at Home Depot. It's in the section where they have the weathwer stripping.
You'll need about 15' per door... I didn't do the rear hatch yet but I would by another 30' package for it.
Old Jul 15, 2009 | 12:04 PM
aortizexcursion's Avatar
aortizexcursion
Do the doors shut with about the same effort as they required before the mod?
Old Jul 15, 2009 | 06:23 PM
CanadianSmokie
There is no noticable difference in door closure. What I did notice though is once door is closed, I can't push it in any further which I could do before the mod.
Old Jul 15, 2009 | 07:22 PM
jdadamsjr's Avatar
jdadamsjr
Sounds like your door catches needed adjusting then
Glad it helped fer sure - I did the silicone tubing in the 03 Ex... haven't taken the time to do my 05 yet....
BigBlkEX
Sep 11, 2014 03:35 PM
Fosters
Oct 31, 2008 10:04 AM
JoeCool223
Oct 17, 2006 09:27 AM
Forrest_F150
2004 - 2008 F150
Aug 24, 2005 07:16 AM
