Sponsored by: Real Truck
Fueling problem
Old Jul 14, 2009 | 03:19 AM
3006banger's Avatar
3006banger
Fueling problem
Can someone tell me why I cannot fuel my truck without first putting the gas in a container then slowly pouring it in? I figure the vent line is plugged somewhere, maybe? So I traced the vent line all the way to the back of the truck up underneath the spare tire in to some kind of plastic component that has other hoses and wires hooked to it. It appears there is a sensor in it.
Can someone tell me what this is as well?
Thanks in advance!
Old Jul 14, 2009 | 08:19 AM
Shiner Bock's Avatar
Shiner Bock
What happens, the fuel pump keeps kicking off?
Old Jul 14, 2009 | 08:51 AM
Primetime1's Avatar
Primetime1
I had this problem with my 05. I could only get 2 gallons in before the filling pump shut off. It was a real pain because it took so long to fill the tank. The service manager said it will eventually throw a code and affect things like power and mileage - not too sure how unless it also affects the fuel feed to the engine. It was under warranty and the dealer knew right away what it was and was able to fix it. I'll see if I can find the paperwork and post later to let you know what the part was.
Old Jul 14, 2009 | 10:32 AM
Shiner Bock
I'd appreciate that info because that's the problem I'm having.
Old Jul 14, 2009 | 11:11 AM
Primetime1's Avatar
Primetime1
OK here you go. This is what they did and it fixed mine.
TSB 072313C
Installed 7C3Z 9049 A : Tube - Ventilation
Installed 6C3Z 9D653 F : Cannister - Fuel Vapour ST
Installed 8C3Z 9030 A : Cap ASY - Fuel Tank Filler
Replaced EVAP Cannister & Fueld Cap per TSB 07-23-13
Hope that gets you fixed up - it did on mine.
Old Jul 14, 2009 | 06:02 PM
Shiner Bock
Thanks for the info. If you don't mind, could you tell me what they charged you to fix that?
Old Jul 15, 2009 | 05:03 AM
3006banger's Avatar
3006banger
Thanks a bunch.
Old Jul 16, 2009 | 09:01 AM
Primetime1's Avatar
Primetime1
It was under warranty at the time, so I have no idea. Sorry. They had it less than a day, so it couldn't be too bad.
Hardlanding
Sep 25, 2015 08:19 AM
MSgtling
Apr 6, 2015 10:41 AM
chaser1602
Mar 28, 2015 05:28 AM
salf100
Jun 21, 2014 10:32 AM
