How do you know when the compressor is bad?
Old Jul 13, 2009 | 11:31 PM
MrRogers's Avatar
MrRogers
I've got a 90 f150 w/ the 302 and it had ac. bought the truck and the ac didn't work. I know the compressor clutch is bad but is there a way to know if i should just get a whole new compressor or swap out the clutch. Also, don't know if any of the other ac components work. I know there's pressure in the system. Any ideas? It's been 3 or so years since i bought it and just never really needed the ac but now i gotta get places and not be sweaty so the cool air would help. Thanks guys...
Josh
Old Jul 14, 2009 | 04:10 AM
Lazy K's Avatar
Lazy K
One thing you could try is, with engine off, turn the compressor over by hand. With some freon in it it should turn over easy but feel like turning over a small lawnmower engine- a bit of compression then none, abit of compression then none. You may have to put a small wrench on the pulley center nut to turn it over.
Old Jul 14, 2009 | 04:25 AM
ford390gashog's Avatar
ford390gashog
if the system still has pressure its a good sign. The pump has no leaks and may just need a new clutch.
Old Jul 14, 2009 | 09:11 PM
MrRogers's Avatar
MrRogers
alright i'll give it a turn. I hope it ain't busted. It's about 2 bills more for a compressor than just the clutch. thanks guys
