6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Just Ordered Spartan
Old Jul 13, 2009 | 12:14 PM
sawtooth's Avatar
sawtooth
Talking Just Ordered Spartan
I just ordered Spartan with the 75, 150, and 210. May end up with the 275+ tune as well. I can't wait to see what she can do. Thanks for everyone's positive comments as this sure looks to be the way to go. By the way, i was on You Tube and searched "Spartan diesel 6.4" and was amazed at how fast these trucks are with the 275 tune.
Truely amazing!!!!!
Old Jul 13, 2009 | 02:11 PM
smotrs's Avatar
smotrs
You should see the videos with the 310. Damn.
Old Jul 13, 2009 | 06:13 PM
benmoderow's Avatar
benmoderow
yep, the hardest part for ya now is waiting for the tunes, it's a long 24 hrs. 275 is definetly worth the extra money.
Old Jul 13, 2009 | 07:41 PM
Brandon D's Avatar
Brandon D
Lead Foot User
Hey Sawtooth,
A couple tips for you to make your life easier. Not sure if you are replacing the entire exhaust or just removing the DPF? If you are doing the entire exhaust then unbolt the hangers from the frame and then screw with them on the ground, this will save you some headache. Same thing on the way back in, put the hangers on exhaust and then hold it in place and rebolt them to the frame.
Also if you are doing the entire exhaust, put a jack under the trailer hitch and jack up the rear of the truck as high as it will go, this'll give you the clearance you need to wiggle the tail pipe over the rear diff but be carfeful not to snag or break any brake lines. As well buy a spare sensor (the main one in the DPF) as it's a real PIA to take out and most guys end up breaking them. If you need any other help or advice let us know. I would also highly recommend the 275 tune or wait a few months and buy the 310 when it's released.
Good Luck
Old Jul 13, 2009 | 08:12 PM
sawtooth's Avatar
sawtooth
Originally Posted by Brandon D
Hey Sawtooth,
Good Luck
Thanks for the info. I decided to do the dpf only as i wanted the truck as quiet as possible (for hunting). Matt told me that by doing this way i was only loosing about 10hp so not to big of an issue for me. As you mentioned i order the extra sensor as well. Thanks for the info and i'll let you know if i hit any bumps along the way.
Old Jul 13, 2009 | 09:11 PM
mick1955's Avatar
mick1955
If you need help setting up you DashDAQ, let me know. Also I have a lot of extra themes and other things for the DashDAQ. PM me you email address and I'll get them to you. Sending you a pm.
Old Jul 13, 2009 | 09:57 PM
sbaset's Avatar
sbaset
How much are those extra DPF sensors? Just curious.
Old Jul 14, 2009 | 06:16 AM
sawtooth's Avatar
sawtooth
I paid about $65 with shipping but you may find it cheaper. You need the sensor that goes in the dpf. You could just remove the one in the dpf but i hear its very hard to do and you may break it anyway trying to get it out.
