EGR Delete question
Old Jul 13, 2009 | 09:55 AM
G.Landry's Avatar
G.Landry
Question EGR Delete question
Just to be sure here... To perform EGR delete all that's involved is to disconnect wire (with engine and key OFF to assure valve is closed) and remove butterfly from throttle body (if it's there) ?
Old Jul 13, 2009 | 11:20 AM
SHAWN056.0's Avatar
SHAWN056.0
Man there's a million posts on this subject. You'll find 10 different answers on this. And by the way do you think your dad will be ok with you unplugging stuff on his truck? Not trying to be an a#%hole or anything but he did pay for it.
natem8301's Avatar
natem8301
Just disconnecting the EGR valve isn't the most effective way to delete EGR keep doing research there are tons of options.
The butterfly doesn't HAVE to come out if you have it....
Old Jul 13, 2009 | 11:29 AM
KRDiesel's Avatar
KRDiesel
What year?? 05-07 will set a MIL condition and cause the turbo to enter a "limp" condition.
Old Jul 13, 2009 | 11:34 AM
qwertmonkey's Avatar
qwertmonkey
Are you sure about this? I have a 2005 6.0 and I disconnected the EGR wire and there was no significant difference.
Old Jul 13, 2009 | 11:37 AM
KRDiesel's Avatar
KRDiesel
What flash are you running? If you have the buzz or inductive I am sure.
Old Jul 13, 2009 | 11:39 AM
qwertmonkey
My truck is bone stock. I'm not sure about the flash, but I've never had it flashed at the dealer.
Old Jul 13, 2009 | 11:40 AM
KRDiesel's Avatar
KRDiesel
Where are you located?
You may have a older flash that does not have the "EPA" mode. Do a search on EPA mode.
Old Jul 13, 2009 | 11:43 AM
qwertmonkey
I'm located in the midwest. Would it be advantageous to have the update?
Old Jul 13, 2009 | 11:50 AM
G.Landry's Avatar
G.Landry
We live in Louisiana. Not a Cali truck. My Dad trusts me completely working on his truck. It's an '03. No tuner yet, will be purchasing a SCT X3 and an MBRP turbo back exhaust kit (keeping cat).
Old Jul 13, 2009 | 11:52 AM
KRDiesel's Avatar
KRDiesel
It helps with the cold start issues, with the latest flash I do not have to plug in untill it gets in the lower 20's
Old Jul 13, 2009 | 11:54 AM
KRDiesel's Avatar
KRDiesel
03 does not have the limp mode IF you pull the plug after the VGT relearn.
And I bet you do not have cold start problems in LA.
Old Jul 13, 2009 | 11:58 AM
G.Landry's Avatar
G.Landry
No, it rarely gets that cold in La.
Old Jul 13, 2009 | 12:00 PM
KRDiesel's Avatar
KRDiesel
Duh, that was a joke.
Your 03, have you done anything to it. I have 161,000 miles on mine and love it.
Have you joined your local chapter?
Old Jul 13, 2009 | 12:05 PM
G.Landry's Avatar
G.Landry
No mods yet
