1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
fuel bowl heater in a v10?
Old 07-13-2009, 12:24 AM
03SDRockstar's Avatar
03SDRockstar
03SDRockstar is offline
just recently my 03 f250 v10 started blowin the fuse for the fuel pump. after reading threw these threads i found out i could just unplug the fuel bowl heater and be good.
question is... does my v10 gasoline have one since i doubt gas would gel up. and if it does, is it in the tank. if not, any ideas what it might be?
just thought id ask a few questions before i start doin uneeded work.
Old 07-13-2009, 12:10 PM
aldridgec's Avatar
aldridgec
aldridgec is offline
I don't think so, if you are blowing the FP fuse, there is a short or it is starting to go bad and drawing too much current.
Old 07-13-2009, 04:40 PM
03SDRockstar
well i didnt want that to happpen either. so i guess ill just be in my driveway droppin the tank...
Old 07-13-2009, 05:02 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
OR that the fuel pump relay contacts are going bad
Old 07-13-2009, 05:24 PM
aldridgec's Avatar
aldridgec
Can't say I've ever seen a relay blow a fuse that way, but it's a good thought! Makes sense!
Old 07-13-2009, 05:27 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Too much resistance at the contacts, will send not enough voltage to the pump. Which makes it take more current. Blowing the fuse.
Bad connections will do it too.
Old 07-13-2009, 10:38 PM
03SDRockstar
and thats why im not a big fan of wiring... but ill take a look into it. thanks yall.
