t19 binding on shift ?
Old Jul 12, 2009 | 07:28 PM
roadrash63's Avatar
roadrash63
hi
ive got a t-19 binding on shift up to third and down to second gear.
seems ive got to play with to get it in ....(ha, ha ) gear.
maybe im just not used to truck 4 speeds.
any help will be appreciated ...
thanks
RR63
Old Jul 12, 2009 | 07:49 PM
Franklin2's Avatar
Franklin2
Might be the clutch. With the engine running, and the tranny in neutral, push in the clutch and then try to go in reverse. If you wait a couple of seconds, and then put the tranny in reverse, you might get a little scrape of the gears, but not much. If it scrapes and scrapes and won't go in, you have a clutch problem.
Old Jul 12, 2009 | 08:43 PM
roadrash63's Avatar
roadrash63
t19
hi
thx for the assist but ive never had any problem going into reverse.
tho the clutch does seem to slip a bit in 2nd gear.
maybe something is binding?
Ty
RR63
Old Jul 13, 2009 | 08:26 PM
hilgerbeast's Avatar
hilgerbeast
throw-out fork issue? slave cylinder issue?
_______________________________
1986 F250 XLT Lariat 4x4 with 6.9L IDI
