Off-The-Wall ? - floor mat graphic
There are plain floor mats without the gear and bolt for standard cabs and the gear and bolt for custom cabs. The gear and bolt will also be embossed into the center of the vinyl seat back mid point in the middle of a ford crest. I have seen the gear on the hump, and also on each floor board depending on the year. For the two wheel drives in 65 Custom Cabs received a color matched mat that did not have the gear and bolt symbol.
NOS mats with the gear and bolt sell for obscene money...
No aftermarket supplier makes one with the correct embossing as the amount they could sell verses what Ford wants to license it is cost prohibitive. Hopefully one of the larger repop houses will step up to the plate and make them. I have only been waiting thirty five years......
Garbz
Garbz
Garbz
Garbz
My '61 regular cab had the gear/lightning bolts on the floor mat. As far as I know it was the original.
I thought the Dennis Carpenter ones had the logo. I guess that's not the case. Bummer. The gear/lightning bolt logo is really cool. It is what really sets the old trucks apart from the '67 and newer ones.
Early 60s hood ornament with the ( Gear & Bolt ) was used on 6 Cyl, and V8s Prior to 1965 !
Wally Womack
the gear and lightening was used on all 61-6 trucks in certain areas depending on the model and engine...
the gear and lightening bolt insignia was used in the following locations:
Hood Badge: 1961-4, all 61-4 F100-350, 1965 and 1966 with 6 cylinder engines.
Seat back upper center: 1965-66 Custom Cab trimmed trucks embossed in the vinyl.
Horn button: Base model trucks with cast horn button(2WD only as I recall)
Floor mat: center of trans hump at forward end. Used on Automatic and 3 speed column shift trucks. Base model only. Also used on 4WD trucks.
The floormats used on 65-6 trucks, for example, are the same on 2WD trucks with auto and 3 speed trucks...no tall trans tunnel like the 4 speeds with the removable tunnel cover. With the 4 speed shifters location, there is no room for the logo even if they wanted to put it in there...
- cs65
- cs65
As far as the seat goes, SMS Auto Fabrics can put the original embossed FORD and gear/bolt emblem in the vinyl (last I heard was an additional $75 bucks or thereabouts).
On the floormats, MAC's sells floormats that have the '100' crest sewn into them - looks like the cowl emblems. $105 for a set.
Just some additional ideas.
4x4x4x4
1999 to 2016 Super Duty
08-12-2002 10:18 AM
