4wd to 2wd
4wd to 2wd
96 Explorer sport, Control Trac, 5 spd. Just changed the t/c fluid hoping it would correct the non operating 4x4. Well during the test drive in 4x4 hi, I heard and felt a big thump from under the truck, and the 4x4 bound up during a turn. Got back home and now there's a crack in the rear of the transfer case at the drain plug and it's dripping fluid. So due to limited money (retired) I'm thinking I could remove the t/c and go to the 2wd drive set up. Can anyone tell if this can be done and what parts I would need? Or maybe sell the Explorer and maybe get $1500.oo for it?
Comments?????????
Comments?????????
Let me know which of these you have, I can get you a transfer case easily and very affordable compared to most. I own a salvage yard and have electronic access to over 1800 other yards. So I get to see the lowest price out there.
<INPUT id=0 type=radio CHECKED value=@B=}}} name=userInterchange><LABEL for=0>4x4 (part time, electric shift), ID F57A-7A195-CA</LABEL>
<INPUT id=1 type=radio value="@B>}}}" name=userInterchange><LABEL for=1>AWD (full time), 4 bolt hole circular front output flange</LABEL>
<INPUT id=2 type=radio value=A@D}}} name=userInterchange><LABEL for=2>4x4 (part time, electric shift), ID F67A-7A195-RA</LABEL>
<INPUT id=3 type=radio value=AAB}}} name=userInterchange><LABEL for=3>AWD (full time), 6 bolt hole cup front output flange</LABEL>
<INPUT id=4 type=radio value=A@D}}} name=userInterchange><LABEL for=4>4x4 (part time, electric shift), ID F77A-7A195-GA</LABEL>
Transfer case needed
<input id="0" checked="checked" value="@B=}}}" name="userInterchange" type="radio"><label for="0">4x4 (part time, electric shift), ID F57A-7A195-CA</label>
<input id="1" value="@B>}}}" name="userInterchange" type="radio"><label for="1">AWD (full time), 4 bolt hole circular front output flange</label>
<input id="2" value="A@D}}}" name="userInterchange" type="radio"><label for="2">4x4 (part time, electric shift), ID F67A-7A195-RA</label>
<input id="3" value="AAB}}}" name="userInterchange" type="radio"><label for="3">AWD (full time), 6 bolt hole cup front output flange</label>
<input id="4" value="A@D}}}" name="userInterchange" type="radio"><label for="4">4x4 (part time, electric shift), ID F77A-7A195-GA</label>
Vince
tncamoman
931 738 0257
Thanks hun!
h82loseejr
02-13-2016 12:43 AM
williameub
16
01-11-2016 04:39 PM
hdel
02-07-2015 03:08 PM
uscgrad93
10-16-2014 01:58 PM
