4wd to 2wd
Old Oct 23, 2006 | 10:47 PM
slowfour's Avatar
slowfour
4wd to 2wd
96 Explorer sport, Control Trac, 5 spd. Just changed the t/c fluid hoping it would correct the non operating 4x4. Well during the test drive in 4x4 hi, I heard and felt a big thump from under the truck, and the 4x4 bound up during a turn. Got back home and now there's a crack in the rear of the transfer case at the drain plug and it's dripping fluid. So due to limited money (retired) I'm thinking I could remove the t/c and go to the 2wd drive set up. Can anyone tell if this can be done and what parts I would need? Or maybe sell the Explorer and maybe get $1500.oo for it?
Comments?????????
Old Oct 24, 2006 | 07:50 AM
Backin72's Avatar
Backin72
Why not try and get a used transfer case from your local salvage yard?
Old Oct 26, 2006 | 07:29 AM
Coastiejoe's Avatar
Coastiejoe
Let me know which of these you have, I can get you a transfer case easily and very affordable compared to most. I own a salvage yard and have electronic access to over 1800 other yards. So I get to see the lowest price out there.
<INPUT id=0 type=radio CHECKED value=@B=}}} name=userInterchange><LABEL for=0>4x4 (part time, electric shift), ID F57A-7A195-CA</LABEL>
<INPUT id=1 type=radio value="@B>}}}" name=userInterchange><LABEL for=1>AWD (full time), 4 bolt hole circular front output flange</LABEL>
<INPUT id=2 type=radio value=A@D}}} name=userInterchange><LABEL for=2>4x4 (part time, electric shift), ID F67A-7A195-RA</LABEL>
<INPUT id=3 type=radio value=AAB}}} name=userInterchange><LABEL for=3>AWD (full time), 6 bolt hole cup front output flange</LABEL>
<INPUT id=4 type=radio value=A@D}}} name=userInterchange><LABEL for=4>4x4 (part time, electric shift), ID F77A-7A195-GA</LABEL>
Old Oct 27, 2006 | 09:16 AM
slowfour's Avatar
slowfour
If you are referring to carpart.com, I've already tried that. But anyway it's tag number F57A-CA or the first item in your list.
Thanks
Old Jan 3, 2007 | 01:01 PM
tncamoman's Avatar
tncamoman
Transfer case needed
<input id="0" checked="checked" value="@B=}}}" name="userInterchange" type="radio"><label for="0">4x4 (part time, electric shift), ID F57A-7A195-CA</label>
<input id="1" value="@B>}}}" name="userInterchange" type="radio"><label for="1">AWD (full time), 4 bolt hole circular front output flange</label>
<input id="2" value="A@D}}}" name="userInterchange" type="radio"><label for="2">4x4 (part time, electric shift), ID F67A-7A195-RA</label>
<input id="3" value="AAB}}}" name="userInterchange" type="radio"><label for="3">AWD (full time), 6 bolt hole cup front output flange</label>
<input id="4" value="A@D}}}" name="userInterchange" type="radio"><label for="4">4x4 (part time, electric shift), ID F77A-7A195-GA</label>
I have the last one with the GA on the end. I need one of these with a warranty. Can you find me one?
Vince
tncamoman
931 738 0257
Old Sep 23, 2009 | 05:52 PM
ladyj14's Avatar
ladyj14
Hey I need a transfer case and was thinkin about doin the 2wd insted of buyin a whole transfer case! Everyone i find is sooooo expensive can you give me a quote on how much yours would be. I need the F77A-7A195-GA! Can you send the quoote to my email jdollarhide970@yahoo.com
Thanks hun!
Golflover
41
May 24, 2016 11:14 PM
h82loseejr
Feb 13, 2016 12:43 AM
williameub
16
Jan 11, 2016 04:39 PM
hdel
Feb 7, 2015 03:08 PM
uscgrad93
Oct 16, 2014 01:58 PM
