Request help in timing 2.3l DOHC chain 2001
I bought a new crankshaft sensor but there are no alignment instructions with the sensor, are there sussposed to be instructions?
Anyway could you provide me instructions on how to align this as the manual does not provide alignment instructions?
I already have the engine at TDC and the valves are all lined up as well.
I know I need to have the crankshaft pulley aligned with the 6 mm bolt that goes through the timing cover, but how is the alignment for the crankshaft sensor achieved?
Thanks for any help you can provide!
Troy
Troy
This is the procedure from the manual. It may not be what you want to hear,
3. Disconnect the crankshaft position (CKP) sensor electrical connector.
4. Remove the plug for the Crankshaft Timing Peg.
5. Install the Crankshaft Timing Peg and turn the crankshaft pulley bolt to position the number one cylinder at top dead center.
6. Remove the CKP.
7. Install the Timing Pin.
Installation
1. Install the CKP, but do not tighten the bolts at this time.
2. Adjust the CKP with the Crankshaft Position Sensor Alignment Jig and tighten the bolts.
3. Connect the CKP electrical connector.
4. Remove the Timing Pin.
5. Remove the Crankshaft Timing Peg.
6. Install the plug.
6. Remove the CKP.
Installation
macubus
2004 - 2008 F150
08-03-2019 01:03 PM
81ChopTop
64
04-23-2016 06:51 PM
