mod idea
Old Jul 11, 2009 | 06:20 PM
17fordguy's Avatar
17fordguy
mod idea
i was looking thrue some jeep articlesand saw one that would be nice for my truck they turned a york ac compressor into an air pump. the york comppresor uses a external lubricant source instead of the freon. any body heard of doing this on our trucks?
Old Jul 11, 2009 | 06:39 PM
dustybumpers's Avatar
dustybumpers
have 1 on and old truck. make sure to use a pressure cutoff switch. pumps good, blow up tires, etc, but won't run air tools.
Old Jul 11, 2009 | 06:41 PM
17fordguy's Avatar
17fordguy
how do you keep the compressor on these trucks lubricated without the freon thogh?
Old Jul 11, 2009 | 06:59 PM
dustybumpers
it's an old piston style pump, has a oil level in the bottom just like a lawn mower
Old Jul 11, 2009 | 07:01 PM
17fordguy's Avatar
17fordguy
but how can the york comprossor be used on our trucks or can our existing pmp be modified to work?
Old Jul 11, 2009 | 07:06 PM
*2fords*'s Avatar
*2fords*
I have one on my Jeep. I built it more than 16 years ago and has been great having it. I have mine run into an old air tank off an International semi truck. The lube is plain ole 30 weight oil. It will pump the oil out so you have to have an oil collector plumbed so the oil will go back into the pump. I found that out after finding oil in the air hose . and burning up the first compressor I had. I've got a pressure release valve, a pressure regulator, and a coiled hose that stretches 25'.
Old Jul 11, 2009 | 07:20 PM
dustybumpers
new style rotery pump won't work, has to be the old style york. came on 70's to early 80's fords
Old Jul 11, 2009 | 07:24 PM
17fordguy's Avatar
17fordguy
ok thanks thatrs what i was lookin for.
Old Jul 11, 2009 | 07:41 PM
dustybumpers
you can't miss them big square thing with a huge clutch. make sure to get the wire hook up, it's a bit odd, just cut it, and splice on a new wire
Old Jul 11, 2009 | 07:53 PM
17fordguy's Avatar
17fordguy
how can i bolt this setup to my 96 300? should i grab the bracket to or will i be good with the one i have?
Old Jul 11, 2009 | 08:07 PM
dustybumpers
probably going to have to fabracate something, and figgure out how to get a v pully to bolt to your balancer. then need a tank somewhere, with a pressure switch to cut the compresser on and off. do able, but going to require some thought and designing
