Distributor Fit
Old Jul 11, 2009 | 04:39 PM
Hillcapper's Avatar
Hillcapper
Distributor Fit
Finally finishing up my 5.0 swap for the 4.9 currently in my 94 F150. Using a 1990 donor truck for enignie wiring harness and computer etc... I cant use the distributor though due to a cast gear. I ordered a steel gear and they sent me the wrong one. So I've decided to just go with a complete distributor.
So, I've seen some great deals on 5.0 distributors (ebay) out of Mustangs. Should be compatible for my application correct?
Thanks
Craig
Old Jul 11, 2009 | 04:44 PM
lew52's Avatar
lew52
The HOs have the steel gears , you should be good to go with that ..Lew
Old Jul 11, 2009 | 04:51 PM
Hillcapper's Avatar
Hillcapper
Thanks Lew, should be 'plug and play' then, as far as the ignition correct? Still love your truck!
Old Jul 11, 2009 | 05:00 PM
lew52's Avatar
lew52
Yeah as far as i know its the same distributer , or any dist out of a roller truck will have the steel gear.. So your just about done . I think you will like it , would like to see it when its done ... Lew
Old Jul 11, 2009 | 05:18 PM
Hillcapper's Avatar
Hillcapper
Thanks Lew, I'll post some pictures once its ready to swap.
