Adjustable Lifters
Old Jul 11, 2009 | 11:06 AM
cts1954's Avatar
cts1954
Adjustable Lifters
As the Lifter Turns, a continuing story
I got my valves out and removed the lifters, they are a solid body type with the 2 section screw. From what I can read the Johnson style were hollow type and that is what is on Red Headers web page for sale. Is the hollow lifter the way to go as they are lighter and as mine are solid does that indicate that they are poor reproductions.
Thanks
Old Jul 11, 2009 | 01:24 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Solid ones were used (still are) on Ford tractors. Yeah, they're heavier, so if you want to wind your flatty out to 6,000 RPM there will be problems. Seriously, lots of folks have used the tractor lifters on the street with no problems. No question the hollow lifters are better for high-RPM use. The real issue is quality. Ford tractor lifters are solid but properly made. The radius on the lifter face, materials, heat treatment and surface fiinish are all factors. From what I've seen on the net (no personal experience), some of the chinese ones were inferior in just about every category. Most common problem (as you found) was the screw not holding.
Best lifter ever made IMO was the stock non-adjustable. They weigh a fraction of any adjustable, and are works of art as far as construction. They are available remanufactured, but it could mean more valve grinding is needed to get the right clearance.
Old Jul 11, 2009 | 05:22 PM
cts1954's Avatar
cts1954
Thanks Ross
I will not be winding my flathead up to anywhere near 6000 rpm, I will have too much money in it. I just want to put the right parts in at the right time. It looks like the ones sold by Reds Headers are hollow compared to my solid ones, makes sense to keep the weight down. I just want to adjust the clearance and drive it normally without it sounding like a thrashing machine.
