squeaky wheel gets the grease?
Old Jul 10, 2009 | 10:25 PM
cbass139's Avatar
cbass139
my steering wheel (I pressume that it is actually the column) has started squeaking. Where do I need to grease or oil to get this to stop? It doesnt say anything about it in the manual.
Old Jul 11, 2009 | 04:26 PM
cbass139's Avatar
cbass139
Nobody has had this problem? I presume that it is coming either from the point were the wheel connects to the column or the shaft is making contact someplace. I am not sure were to oil or grease and what kind to use? Anybody have experience with this? Thanks
Cbass
Old Jul 12, 2009 | 02:32 AM
Steve_B's Avatar
Steve_B
There is a bearing in the top of the tube
You will have to remove your steering wheel to reach it
Steve
Old Jul 12, 2009 | 05:06 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
It could also just be a dry horn ring. Either way you'll need to pull the wheel and see what you find.
Old Jul 12, 2009 | 05:50 AM
cbass139's Avatar
cbass139
Ok, and just use a good weight grease on the bearing? And what do you do about a dry horn ring? I will take a look in the manual but incase it is not in there, please let me know.
thanks,
Cbass
