Does it even exist???
Old Jul 10, 2009 | 10:09 PM
g16classified's Avatar
g16classified
Talking Does it even exist???
I am in the market for a 69-75 ford pick up, but here's the catch. I want a quad cab (four actual doors), with a longbed (8 ft box at least). I don't care if it is running or not, just hopefully not tooo much cancer. or huge dents. basicallly if it hasn't been hit by a train or sat in the east coast rains for 10 years it will do. but first i have to know if those were even made to begin with. last question is... how hard would it be to buy a quadcab with a short bed and put a long bed onto it? would i need to extend the frame? thanks to any and all that can possibly help me out with this.
Old Jul 10, 2009 | 10:17 PM
custom1106's Avatar
custom1106
I belive that 67-72 trucks like these do exist...as well as the 73-79 flavor. You'll only find them with 3/4 or higher running gear. I have only seen a couple...not as common at the 4 door shortbeds. I belive all 4 doors were built in canada?.....I'm sure someone will step in to correct me if I'm wrong.
Old Jul 11, 2009 | 12:05 AM
garbz2's Avatar
garbz2
The long bed factory crews came only in F350 trim and 2 wheel drive.
Here is a short bed crew which is the more common type.
Garbz
Old Jul 11, 2009 | 12:14 AM
garbz2's Avatar
garbz2
Here is one BAD A$$ crew for sale here in Arizona
http://phoenix.craigslist.org/evl/cto/1263443360.html
Here is a great deal on the basics and rust free AZ metal.
http://phoenix.craigslist.org/nph/cto/1262846899.html
Garbz
Old Jul 11, 2009 | 07:17 PM
MotorDog's Avatar
MotorDog
Crew Cab.............
1967 to 1972 Crew Cabs came in many wheel bases. The common 4 x 4 F-250 has a short bed and is 149 inches axle to axle. The F-350 2 WD crew cabs were a 169 inch wheelbase, 20 inches longer! They came with either a Stepside or Styleside 8 ft. bed on them. This is what you probably want. I have a 69 that needs restoration I might consider selling. It is complete and is a Contractor Special with 47,000 actual miles and the original title. If interested, e-mail me..... Good Luck!
Old Jul 12, 2009 | 11:40 PM
wyoming4x4's Avatar
wyoming4x4
I know where a crew cab frame and drivetrain complete is setting. I aquired the cab and building up a truck as we speak with the cab but using modern drivetrain and a cummins conversion. This chasis is on tires just needs everythings on top 4wd long wheelbase frame 1969. drop me a PM if curious and it'll probably go cheap because the owner past away earlier this year and cleaning up the property.
Old Jul 14, 2009 | 08:13 PM
dohc_chump's Avatar
dohc_chump
This space for rent...
My buddy has a '72 Hi-Boy 4x4 Crew Cab that was once a shortbed. I know they extended the frame around 20". He had issues with the dual tanks fitting right once it was stretched. Be careful where you cut to make your extension pieces because you can mess up where the bed bolts on. Here's a pic of his crew.
Old Jul 23, 2009 | 01:40 PM
rdfunke's Avatar
rdfunke
Here is a site that you can check out. Tons of info on the type of truck you are asking about. www.oldfordcrewcabs.com
Old Jul 23, 2009 | 10:41 PM
garbz2's Avatar
garbz2
I like........My crew is also low miles so i dont want to cut and extend it. But is sure would look sweet with adaptors and 20 inch budds.
Garbz
tacson
Mar 9, 2015 06:44 PM
SMLWinds
Mar 3, 2015 03:27 PM
perryg114
1983 - 2012 Ranger & B-Series
May 31, 2012 02:48 PM
jfish045
Mar 19, 2012 07:58 AM
week0019
2004 - 2008 F150
21
Jan 9, 2009 05:47 AM
