Blinker problem
Old Jul 10, 2009 | 03:28 PM
diamonddave242's Avatar
diamonddave242
Blinker problem
The blinker will no longer automatically turn off after you complete a turn. Can someone tell me how to fix this?
Thanks.
Old Jul 10, 2009 | 04:25 PM
g_k50's Avatar
g_k50
This is from the 1999 Ranger Service Manual.
Visually inspect for obvious signs of mechanical and electrical damage.
Check fuses, Damaged wiring harness, Loose or corroded connections
If the fault is not visually evident, detrming the symptom and proceed to symptom chart.
Are the signal lamps never on?
Are the Hazard Lamps never on?
Is one turn signal/Hazard lamp never on?
To test the turn switch circuit connect circuit 44 (LB) and 3 (LG/WH) move the switch to the turn left position, a good switch will indicate a closed circuit.
replace flasher.
Old Jul 10, 2009 | 08:50 PM
diamonddave242
The flashers work fine. Not sure if you understand my problem. You know when you put the signal on and then make a turn. The signal will automatically go back to the neutral position. Well, my problem is that the signal will not go back. I have to manually put it back. How do I resolve that?
Old Jul 10, 2009 | 10:19 PM
g_k50's Avatar
g_k50
Maybe I don't understand your problem, what have you tried so far?
Have you inspected for obvious signs of mechanical and electrical damage?
have you checked the fuses, the wiring harness, the connections?
Have you replaced the flasher?
If so replace the multifunction switch.
Old Jul 11, 2009 | 07:32 AM
LMS Residential's Avatar
LMS Residential
Sounds like the multi function switch to me. The return (cam?) is prob worn or broken. Had to do mine in my 97 about a year ago for same prob. Bring your wallet, the switch is pricey.
Old Jul 11, 2009 | 10:54 AM
diamonddave242
Great. :-( Is this a pretty easy job?
Old Jul 11, 2009 | 02:24 PM
g_k50's Avatar
g_k50
Yeah, it's pretty easy, just like Microsoft sezs Plug and Play is easy.
The hard part is paying for it. Y2KFordParts.com has it for 68.77
Old Jul 11, 2009 | 05:03 PM
LMS Residential
Sorry to say but gk50 has it right, its about as easy as pulling your own molar. You have to remove the steering wheel, BE SURE TO DISCONNECT THE BATTERY AS IT WILL DISENGAGE THE AIR BAG. Thats the easy part. Further along the column, your going to have to **** with the connector to get it out and then further **** with plugging in the new switch without shorting one of the many wires or losing a fingertip. The switch itself is easy enough. Wish I would have taken some pics but didnt belong to the forum then. Once you get going its pretty self explanatory but tedious. I got my instruction from a haynes repair manual for the ranger.
Old Jul 11, 2009 | 05:20 PM
g_k50's Avatar
g_k50
My 1999 Ranger manual has 5 steps
Disconnect battery ground cable.
Remove the ignition switch lock cylinder
1. Insert key turn to run
2. Pus the ignition switch lock cylinder release tab with a punch while pulling out the ignition switch lock cylinder
If equipped, remove the tilt wheel handle
Remover the upper and lower steering column shrouds
Remover the multi-function switch. 2 screws and electrical connectors
Install is the reverse
Old Jul 11, 2009 | 05:23 PM
diamonddave242
Thanks for the advice fellas. I found the part on Ebay for about 30 bones. I will get back to you and let you know how it went.
Old Jul 11, 2009 | 08:50 PM
LMS Residential
Jeeze, I could have done that without pulling the steering wheel, that s***s.
Old Jul 18, 2009 | 10:04 AM
diamonddave242
I finish with replacing the multi-function switch. Actually pretty easy....even with the wife talking my ear off. Usually a job like that with the 'ol lady near by would take twice the time. Needless to say, it only took fifteen minutes. I didn't have to worry about the ignition switch, I just disconnected the battery, took out the bottom three screws. I then unscrewed the tilt steering handle and took off the steering wheel shroud.
The hard part was just taking the wires off but all in all, easy job. Thanks for the advice guys.
Old Jul 18, 2009 | 11:06 AM
LMS Residential
glad to hear thats all it was, still grumbling here about pulling the steering wheel when i didnt have to. The manual specifically states to ref "steering wheel - R&R as the first item. I should send a letter.
